app radio 2 problem
By Bodhisattva · May 25, 2014in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,325 views
Posted May 25, 2014 · 11:14 UTC#1
hey all, i picked up one of these cheap locally as it has a problem
its the old "screen image may appear reversed" issue. after a reset or off power for over 5 mins when you switch it on it goes through the language then the press ok bit, the icons pop up for 1 second then its stuck in the "screen image may appear reversed" bit and i can get it out. i dont have the control harness but i manually simulated the handbrake and reverse pins and its still locked out and wont respond. am i being silly and missing something simple.
when simulating the handbrake and reverse i assume you just earth them??
any ideas?
Posted May 25, 2014 · 13:50 UTC#2
forgot to add this is a euro unit, ive been playing all morning and its just stuck on the camera, i cant get out of it no matter what i try and ive searched on here and tried about everything people have suggested :(
Posted Jun 08, 2014 · 19:31 UTC#3
sorted
it was a 12v supply to the reverse switch not an earth. all came back and camera switched off
Posted Sep 15, 2014 · 18:40 UTC#4
i think that it's a software problem!
i have The rear camera with 12v option select, if I touch The rear camera on The right top screen, The radio start one loop show black screen whit the rear camera message and after return to normally function and nex black screen.... The only reset metod is to disable the rear camera in the settings menu, exit and reselect the 12 volt option.
