Surround sound?
By Shackleton · Jun 05, 2014in NEX Series💬 10 posts👁️ 1,421 views
Posted Jun 05, 2014 · 03:34 UTC#1
I assumed the NEX line had at least 5.1 Dolby digital surround, my bad.
Posted Jun 05, 2014 · 04:03 UTC#2
why do you want to do surround in your car? either way it is most likely down mixing to LtRt aka stereo
Edited Jun 05, 2014 by myke2241
Posted Jun 05, 2014 · 10:39 UTC#4
It decodes Dolby, it decodes dots, com, but in mention in the manual of what output it provides. So I'm unsure myself
Posted Jun 05, 2014 · 16:20 UTC#5
What is dots and com?
Edited Jun 05, 2014 by Shackleton
Posted Jun 05, 2014 · 18:13 UTC#6
I'm sure that dot is dts that has been autocorrected. Not sure about com (maybe pcm)
Posted Jun 05, 2014 · 21:10 UTC#7
lol friggin auto correct yes it is dts and PCM
Posted Jun 05, 2014 · 23:34 UTC#8
I should have figured that out looks like it does do 5.1 dolby digital but not dts
Posted Jun 06, 2014 · 19:31 UTC#9
Actually It doesnt even really do DD because there is not true center channel. Althought my system comes close with two extra tweeters in the middle air vents the only speaker that are running off the head unit
Posted Jun 06, 2014 · 20:51 UTC#10
It can do phantom or phase I believe it's called. it uses 2 fronts Just like a home theater that doesn't have a center and simulates the center
