Has anyone found a steering wheel control that will trigger Siri? I know I can press the middle button on the unit, but it would be even nicer if I could keep my hands on the wheel.
I have the AVH-4000NEX installed in my 2007 Jeep Patriot with the PAC RP4-CH11 adapter. I know how to customize which of my steering wheel controls map to which wired remote setting, but none of the ones I tried seemed to work. Here's a list of the wired remote signals the adapter can send to the unit:
- Volume + —Works
- Volume - —Works
- Mute —Didn't test
- Preset + —Didn't test
- Preset - —Didn't test
- Source —Didn't test
- Track + —Works
- Track - —Works
- Band —Didn't test
- Phone Menu —Brings up the phone screen, but does nothing useful
- Answer Call —Answers a call (but can't end it, which is annoying)
- End Call —Ends a call
- Voice Activation —Did nothing when I tried it
The only thing is I had Voice Activation set up for a long-press command, rather than a normal tap. Is it possible it requires a long-press, like the center button? In other words, maybe I need to wire it to a short-press button, but hold it longer.
Setting up these buttons is a huge pain, since you have to press the set button and the steering wheel buttons in exactly the right order, and it only has a 7 second timeout. ![]()
