Hello,
I'm trying to install custom POIs on my AVIC-F930BT...
I found POIs in <*.kml> format.
I have following questions:
1) With NavGate Feeds, I could export them on a SD-card.
But original <*.kml> file is split into several files (size 66K).
Is it a way to avoid this automatic splitting ?
I will try to merge them into a single file, and see if it works.
2) NavGate Feeds creates the following files structure on the SD-cards (exported POI name: POI):
NDB
CUSTOMPOI
POI.kml
POI(2).kml
POI(3).kml
CustomPOI.symb
VersionManage
AUTHENTIFICATION
Custom_POI.aut
Version
Custom_POI.ver
Is it possible to add a sound alert associated to this custom POI ?
If yes, at which place, which name, which format ?
3) Is it a way to copy custom POIs into the built-in memory of the AVIC ?
If not, it means that a SD-card must be inserted permanently to access them.
In this case, it is possible to add other data (Music, ....) on the same SD-card, and make
the device access them simultaneously ? If yes, where should they be installed ?
Thanks in advance for your help.
