AVIC N-1 Screen Calibration success ?
By ermartin · Mar 02, 2007in Problems/Troubleshooting💬 4 posts👁️ 3,107 views
Posted Mar 02, 2007 · 23:34 UTC#1
Has anyone successfully calibrated an N1 screen. I have attempted this for hrs and it never gets any better. will a complete reset help at all ?
Posted Jul 12, 2007 · 07:03 UTC#2
Follow the instructions by REMIX2112 posted Nov 2006. I just did it today and it worked. I learned that all you have to do is press (EQ) botton and then (BAND) to go back in the menu. If you are off alot, I found that all need to do is not trace the outer white line. Just place your pointer a cm from the side. I just used a pointer once at the bottom and once at the top. The values changed ok. **It took me 3 times to figure it out.**
Posted Aug 14, 2007 · 00:43 UTC#3
That still isn't working for me. Is it possible that my screen is just to far gone, or do I need to have the flex cable done first before, I can recal. The screen is stuck in the up position and +- don't work any more. Sorry to highjack the thread :o
Posted Mar 27, 2009 · 01:20 UTC#4
I ran into the same problems calibrating on the left side. I slightly lifted the plastic along the left edge and used a thin stylus. (consider that there is more screen continues under the edgeing). It worked and I was able to complete the calibration process.
