Going to be installing an 8000NEX in a conversion van (2000 Chevy Express base). The OEM unit is larger than single din yet smaller than double din, and also had the premium package with CD drive below it. Currently has a single din HU installed with aftermarket adapter and an OEM utility pocket replacing the CD drive. Here's a picture an OEM unit with the pocket I found on 'net...
Not currently concerned with actual mounting of the unit behind the instrument panel bezel. With the OEM unit not being double din to begin with, I'm not having any luck finding an easy means to make the trim out respectable. An aftermarket bezel with double din opening would be ideal. Otherwise, I'll have to cut out the 'bar' between the OEM unit and pocket in the picture. While cutting it presents no problem, it leaves the problem of concealing or somehow trimming out the cut edges.
Suggestions, tips, recommendations, any help at all appreciated ![]()
