new to me avalanche with x920bt
By harveje · Jun 27, 2014in Problems/Troubleshooting💬 3 posts👁️ 1,427 views
Posted Jun 27, 2014 · 14:46 UTC#1
Good morning, Been trolling and reading but have a few ??
New to me 04 avalanche with an X920bt
1. no additional menu options--all greyed out --I'm assuming something do do with lockout or bypass--plan to pull unit to look at wires and if needed do the yellow/blk wire swap
2. iphone 5 pandora issue-truck has a usb cord and a 3.5mm jack- when hooked up with lightning usb cable i see pandora on the HU screen, the song name and track time is running but no sound.
3. brightness--nav map brightness is a killer at night--- will check the illum wire when I pull out but is there an adjustment?
4. wiring diagram for an 04 av-- where is the best place to find one?
It's been way to many years since I've messed with these, last one was when supertuner just came out----many moons ago.
Again,
Thanks for the help
Posted Jun 30, 2014 · 14:58 UTC#2
OK, after hrs of dicking with this unit
moved the yellow/black mute wire over one space and icons un-grayed, the green brake wire looks to be on a 12+v line, will check with meter
iphone 5 pandora still will not play with HU icon, I can see the song and the counter is running but no sound
brightness------hold mode for a few seconds and a menu pops up---yea
I checked the info and it's at version 5.0--is this the correct version for an x920bt?
how does the app interface work?
Thanks for the help
Posted Feb 28, 2015 · 04:02 UTC#3
Got the same issues. Just upgraded from iPhone 4S to 6. HU rejects audio completely via the Lightning to USB wire.
Edited Feb 28, 2015 by Saab Driver
