install one today and i ground the green parking break wire and it bypassed the unit. i drove it around worked like a charm. i guess this time pioneer made it easy!
avic d3 bypass
did you cut the green wire (cut the red junction off) and just ground it to a screw?
i think it work like that for real maybe pioneer did make it easy for as.
chink, so you just grounded the pb wire and that was it, no flipping of switch or anything?
i just ground the green parking brake lead with the ground wire.
Is your vehicle speed sense wire connected?
yes
Simply grounding the parking break does not enable all functionality. I did this and I still cannot enter nav information.
sorry everybody... disregard the bypass!!! that's partially right. you also have to take out the mute wire and pin it on the emtpy spot on the bottom of the mute wire. then ground it. so on the preout plug... remove the mute wire...pin it to the bottom of it (just right below the mute wire) and ground it with the green and black wire. sorry for the confusion. i just installed 4 of them d3's today! i will post the picture of the pinouts tonight or tomorrow. definately works!!! ipod function is awesome!!! sorry again for the confusion!!!
Yep, this works. the Mute wire moove on the RCA harness is the key.
what car is that in the icon?
Eclipse?
that is one crazy body kit
Yup 3g eclipse.
