Bluetooth Issues - z120bt
By Greatscottz · Jul 06, 2014in Problems/Troubleshooting💬 1 posts👁️ 2,642 views
Posted Jul 06, 2014 · 16:52 UTC#1
Hello everyone, having an annoying issue with the Bluetooth, hopefully I describe it with enough detail.
The Bluetooth firmware is 3.32.
Unit is 5.000.
When registering a new phone via Bluetooth, it registers and connects just fine.
My problem comes in when I turn on the car and the unit tries to connect to my phone.
I think the unit "thinks" it is already connected to something, as when i try to connect my phone, i get the "Disconnect current device" message, even though there is nothing connected.
Image uploading is failing for some reason.
http://i.imgur.com/wvkLlxn.jpg - Disconnect device message.
When it finally does connect, I am able to get audio through the speakers from my phone, however it is in a perpetual connecting to phone mode.
http://i.imgur.com/CAH7AX3.jpg
Tapping on the connect button gives me the error "Please start the connection with the audio device"
http://i.imgur.com/PrBlvqn.jpg
And it then claims the phone has been disconnected.
http://i.imgur.com/z1tWbZM.jpg
However it still is connected for phone audio.
http://i.imgur.com/Os2fLEI.png
Only as a phone, no media.
This is really bugging me, I've tried all methods of resetting the unit to factory to no avail.
Also I should mention this recently started happening, it worked like a charm with the same firmware about a week ago.
I have also tried different phones to eliminate my phone being the problem, same exact thing happens.
Ill do anything to fix this, so if more info is needed, I'm happy to post.
