GPS location slightly off - anyway to calibrate this?
By stiggysaurus · Jul 07, 2014in NEX Series💬 6 posts👁️ 1,389 views
Posted Jul 07, 2014 · 05:46 UTC#1
Hello, this is my first post and thread - I have a 6000NEX. I noticed today that the navigation is slightly off. I remember in older Pioneer units, there was a menu setting that allowed the user to recalibrate location manually. I read the NEX manual but was unable to find anything to fix this. Does anyone have any suggestions?
Posted Jul 07, 2014 · 10:10 UTC#2
If you have the speedpulse (Vss) etc. hooked up (which you really should have ), the system will automatically calibrate over time using map matching....
Posted Jul 07, 2014 · 13:17 UTC#3
I have mentioned about the calibration being off, and the older models having the recalibration as well.  The map can be anywhere from 100ft to 500ft off at times, and my VSS IS hooked up, and all the data lines are full.  After it once did a reset on it's own for no apparent reason, I have reset it myself to try to get the map calibrated with no luck.
Posted Jul 08, 2014 · 02:13 UTC#4
Mine is off as well. Speed pulse was not connected so I'll never be able to tell if that works. It's a bit annoying.
Posted Jul 08, 2014 · 04:20 UTC#5
I'm not familiar with the speed pulse, can someone enlighten me? I had a local shop install my headunit..
