OEM GPS antenna and 8000NEX
By KarNPlay · Jul 08, 2014in NEX Series💬 8 posts👁️ 3,012 views
Posted Jul 08, 2014 · 21:40 UTC#1
Is it possible to connect an existing OEM GPS antenna to the 8000NEX? I'd like to replace my 4.5" stock VW navigation unit with the 8000NEX, but I'd like to be able to use the existing GPS antenna.
Posted Jul 08, 2014 · 22:59 UTC#2
Can't say for certain, but unlikely.  In short, it will require compatible connector/pinout and communication protocol.
FWIW, I installed my GPS module in the OEM location, behind the instrument panel and under the dash top (plastic, no metal above it).  Works fine and hidden from view.
Posted Jul 08, 2014 · 23:24 UTC#4
I know guys on here, have used their oem antenna, but they were gm. Maybe someone will help with this.
Posted Jul 08, 2014 · 23:59 UTC#5
Hmmm... don't know what the connector for the VW antenna looks like, but the other end definitely don't look likes it matches the 8000's...
Perhaps this one...
http://enfigcarstereo.com/ENFIG_GAA_PIO2.html
...from this page...
http://enfigcarstereo.com/vw_radio.html
Edited Jul 08, 2014 by jhren
Posted Jul 09, 2014 · 01:14 UTC#6
Great info and helpful links! I'm looking forward to replacing the stock unit with the 8000NEX, while keeping the install as clean as possible. I'll update if I can get the OEM antenna to work. Now, bring on Carplay!
Posted Jul 11, 2014 · 22:50 UTC#7
Try http://www.tss-radio.com/
I purchased an adapter for my 2011 Camaro to keep my stock XM antenna.
Posted Jul 30, 2014 · 18:28 UTC#8
I also got all of my VW antenna adapters from Enfig. I have a 2013 Passat TDI SEL.
The GPS antenna adapter linked by jhren above worked perfectly for me. I also purchased an AM/FM antenna adapter and SiriusXM antenna adapter from them.
Edited Jul 30, 2014 by Mr. Furious
