Where to plug my stuff in... USB question
By BePrepared · Jul 13, 2014in NEX Series💬 7 posts👁️ 1,361 views
Posted Jul 13, 2014 · 06:48 UTC#1
Okay so i'm having my 8000 installed tuesday, and i need to know where to plug in my peripheral cords.
I'm putting a 4 port USB hub in one, and a dedicated IPHONE 5 plug in the other. Does it matter which one I plug in to port 1 and port 2?
Posted Jul 13, 2014 · 07:12 UTC#2
USB hubs aren't officially supported, however your iPhone needs to go into USB1 for full functionality.
Posted Jul 13, 2014 · 07:56 UTC#3
unpowered usb hubs are too simple not to be supported.... it's just a normal USB split into 4 channels... i'm not so worried about that. I just want to make sure i have my Lightning cable in the right port so i can use it for full functionality with my iPhone. Looks like Port 1 it is
Posted Jul 13, 2014 · 13:35 UTC#4
A switchable hub may work if the HU senses it as a device being unplugged / plugged in when you switch ports.
I very much doubt it will show 4 sources in the HU though if it's unswitched.
Edited Jul 13, 2014 by MarketSqHero
Posted Jul 13, 2014 · 20:56 UTC#5
oh, you misunderstand my goal... the only devices i need to be able to plug in are my iPhone and a Flash drive. I just want the other USB ports to charge things when needed. I don't need the pioneer to be able to read 4 devices from one hub.
Posted Jul 14, 2014 · 01:13 UTC#6
Yes, but most devices that you charge via USB also have some sort of data transfer (e.g. many phones show up on computers as drives).  The HU won't know which device to use if you have more than one plugged in while the HU is on. AFAIK hubs do not assign priority to its ports.
You're better off getting a separate multi-port USB charger.
Posted Jul 18, 2014 · 15:12 UTC#7
That or open up the hub and disconnect the data wires going to the charge only ports the radio wouldn't "see it" but would feel it. You'd be splitting 1.6 amps 4 ways so it wouldn't make for much of a charger. A standalone would be the better option for multiple charging ports.
