4000NEX - No Sound
By pmd5700 · Jul 19, 2014in NEX Series💬 6 posts👁️ 3,422 views
Posted Jul 19, 2014 · 23:14 UTC#1
I'm installing a 4000NEX into a 2015 Subaru WRX. I have the parking brake bypass, ASWC, and Radio wired into a Metra harness. The stereo turns on fine, I get HD radio quickly, but I can't get any sound out of the speakers. I've moved the fader around and still nothing. I've tripple checked the wiring and it seems the speaker wiring is correct. There is no factor amp in the car.
Does this sound like a bad HU? Or is there something messed up with my wiring?
Posted Jul 20, 2014 · 00:28 UTC#2
How we supposed to tell from here...
Could be either...
Or both...
Or something else... :)
Posted Jul 20, 2014 · 00:49 UTC#3
Could be either...
Or both...
I'm just wondering if it seems like an obvious issue that I'm overlooking. I honestly don't think it's the wiring. I've checked that all the connections are landed to the right place. All the joints are soldered and then wrapped with heat shrink. The stock stereo works fine. I'm leaning towards the 4000NEX being faulty, but just trying to see if there are any other ideas before I send it back.
Posted Jul 20, 2014 · 01:27 UTC#4
It sounds like the yellow/black wire(mute) may be getting a signal. check that particular wire and disconnect it, if connected to anything and try it. I did this once on mine. and ended up capping it off.
Posted Jul 20, 2014 · 14:08 UTC#5
I turns out that the blue/white wire on the Metra harness was touching the White speaker wire somewhere within the connector. I pulled the pin out and taped it up. Now it's working fine.
Posted Jul 20, 2014 · 18:36 UTC#6
Cool, glad it is working.
