bluetooth streaming issue
By Harleycop567 · Jul 21, 2014in NEX Series💬 7 posts👁️ 1,433 views
Posted Jul 21, 2014 · 15:16 UTC#1
I have a 7000 Nex that replaced a Kenwood 6990hd that was a glitchy nightmare. LOVE this new unit but having an issue with streaming bluetooth audio (pandora). The phone (gs3) is synced to the unit. The phone works great. If I switch sources to bluetooth audio I get a message on the hu screen that says unavailable unplug devices from the cable. I unplug my ipod video from cable and I can stream music. If I plug the ipod back in it cuts the stream and I get the message again. It is acting like there is a port conflict. Any ideas?
I just had it installed this past friday. And yes the ipod works as it should when selected from hu.
Posted Jul 21, 2014 · 16:02 UTC#2
Have you tried both usb ports? Just a thought.
Posted Jul 21, 2014 · 17:27 UTC#3
Have not tried to switch the usb ports yet. I talked to the installer and he feels it may be a settings issue where ipod is trying to take over the port.
Posted Jul 21, 2014 · 20:16 UTC#4
Usb1 is for iphone, check smartphone setting , and change it to none, if it is set to usb. Or change to usb if it is set to none. Otherwise plug into usb2.
Edited Jul 21, 2014 by joemamma1954
Posted Jul 25, 2014 · 18:19 UTC#5
Update: I had to get the droid cable kit and samsung gs3 adapter. Now pandora is run and controlled by the hu and I do not have to unplug the ipod. A bit more money but got the results I was looking for. Amazing unit!
Posted Aug 15, 2014 · 15:37 UTC#6
I have the exact same problem as the OP. I'm trying to follow joemamma1954's advice, but I don't have "none" option in any of the 8000's smartphone setup settings. I have tried both USB ports, tried both "iphone" and "other" settings but it all fails. As soon as I plug in an iPod Classic, my bluetooth streaming option goes away.
All I really want is my iPod classic and bluetooth streaming from my Galaxy Nexus phone both be available as sources at the same time. I don't need app radio mode or anything like that.
Any ideas?
Posted Aug 17, 2014 · 10:01 UTC#7
If you use Pandora then get the cable kit from pioneer. I think it will work to stream downloaded music from the phone. It is a bit more money (50 for cable kit) but in my case well worth it. It's almost as if pioneer is forcing the sale of the cable kit. Good luck!
