Music source over directions?
By norwestie · Jul 29, 2014in NEX Series💬 7 posts👁️ 1,370 views
Posted Jul 29, 2014 · 15:34 UTC#1
I just installed my 4000NEX and so far I love it. Is there a way of listening to a music source while using a GPS program, like Waze? I searched the manual for "map" and "GPS" but there is no explanation.
Posted Jul 29, 2014 · 19:36 UTC#2
Great question, because it took me forever to figure this out...When you adjust the volume when in map mode you will see two tabs below representing the 2 different sources. select the tab you want to listen to over the maps. Bonus, you may notice a separate volume control all the way to the lower right. Allowing you to hear more than one source at a time.
Cool huh? I literally learned this stuff a few weeks ago and I had a major aha moment.
-Mikemaan
Posted Jul 30, 2014 · 15:41 UTC#3
Thanks, that was simple.
Posted Jul 31, 2014 · 04:53 UTC#4
Is there a way to have navi and have the voice not interrupt the music all together for a sec and so that just overlap each other ?
Edited Jul 31, 2014 by jmontoya21
Posted Jul 31, 2014 · 17:39 UTC#5
Settings > Audio > Mute Level:
  • ATT
  • Mute
  • Off
Posted Aug 03, 2014 · 00:55 UTC#6
<p>
  • ATT
  • Mute
  • Off
Thanks jhren
Worked like a charm
Posted Aug 03, 2014 · 14:41 UTC#7
I just tried again. What I found is that if I am listening to Pandora, it will play over the Waze instructions just fine. But if I select Sirius, then AppRadio to get to Waze, the music goes away. Any suggestions to keep Sirius working?
