NEED HELP!!!! Please... - AVIC 6000NEX troubles...
By gallantcj · Aug 01, 2014in NEX Series💬 8 posts👁️ 1,294 views
Posted Aug 01, 2014 · 23:03 UTC#1
Hi everyone, I need some  assistance with my new 6000 I just had installed today.
I am in the midst of trying to get access to certain system functions and the options are grayed out (ie. Navigation Settings on the map).
Any assistance would be appreciated!
Posted Aug 01, 2014 · 23:07 UTC#2
Need more info of what your trying to do
Posted Aug 01, 2014 · 23:34 UTC#3
OK, well, I want to deactivate the Speed Warning.  I referred to the user manual which tells me to go to the navigation settings, however when I get there, the option I need (Settings) is greyed out and I can't select it.
I don't know why.
Posted Aug 02, 2014 · 01:34 UTC#4
Are you attempting to do this with car setting still or while moving?
Posted Aug 02, 2014 · 01:35 UTC#5
Sitting still.  It isn't just that option that is greyed out, it's a few different menus, can't type in addresses for GPS, etc...
Posted Aug 02, 2014 · 01:39 UTC#6
Parking brake engaged with parking brake wire connected?  ...or bypass 'module' installed? ...or software bypass enabled?
Posted Aug 02, 2014 · 02:13 UTC#7
You probably don't have the parking wire connected properly. I had this issue with mine when I first set it up.
Posted Aug 02, 2014 · 02:34 UTC#8
@jhren:  You must have smelled the saran wrap off of me and my aftermarket virginity...lol.
You called it.  Thanks!
