you can't use appradio mode when you hookup Allshare cast dongle, you need to launch appradio app from the phone.
Why on earth are you using Allshare Cast dongle? what purpose is using this?
Thank you for your kind reply.
So, I resume.
Provided that I use Android phone and I setup in my F60DAB settings on "Phone Connection" as OTHERS and "Type of connection" as HDMI,
Appradio works fine with and my Samsung Note2 phone with HDMI cable conection in the same way it is described in the official Pioneer operating manual.
Everything works fine. Smooth and smart.
But it is a cabled solution.
My goal now is to do the same thing without phisycal cabling my phone.
So, the only solution is to go with "Screen Mirroring" feature available from my phone to transmit HDMI signal to a dongle called "Samsung AllShareCast" that wirelessly receives HDMI inputs from my phone and send it along HDMI cable to F60DAB unit.
So, I hook up Samsung AllShare Cast Dongle to HDMI and USB cables from my F60DAB.
Doing so, Apps button on F60DAB stays grayed.
I think it should become available because anyway it is a HDMI input working (you may do this by plugging the dongle in a tv with HDMI inputs and you may watch the dognle screeen).
For example, if I use Netgear PVT300 dongle instead of Samsung AllShareCast dongle, everything works.
So, if anyone can explain, I'd be grateful.
Thank you
