Trouble updating Z110BT to CNSD-210FM
By tincar23 · Aug 09, 2014in Problems/Troubleshooting💬 5 posts👁️ 1,773 views
Posted Aug 09, 2014 · 21:03 UTC#1
Has anyone had trouble updating the Z110bt with the CNSD-210FM update? The first SD installed with no problem but as it finished a message appeared on the screen "wrong SD card insert correct SD card". I inserted the second SD card but it didn't finish the installation. I've tried re-installing 1.001.000 but the message still appears on the screen. When I take the SD card out I get another message "no SD available. Insert SD to continue"  any other function is inaccessible.
Posted Aug 16, 2014 · 19:46 UTC#2
I've successfully updated my Z110bt with the 2013 Maps.  I suggest you format your SD card.  If you're using WINDOWS, make sure you uncheck "Quick Format".  Then copy over the files to the SD card with nothing else on the card.  See if this works.
Posted Nov 21, 2014 · 02:06 UTC#3
Did you ever manage to fix this?  Mine is boned in the same manner and I need to fix it quick or my wife will kill me!
Posted Nov 21, 2014 · 12:16 UTC#4
Nevermind.. I found my issue.
I will post up a how to later on how to go about fixing it..
Posted Jan 24, 2015 · 06:53 UTC#5
Mightymouse75 did you ever get around to that post?
