X930 "no applicable program" screen
By mitch can · Aug 13, 2014in Problems/Troubleshooting💬 4 posts👁️ 2,366 views
Posted Aug 13, 2014 · 21:47 UTC#1
Hi guys, I just got an x930, not sure what happened to it but it says it has no applicable program. I have searched through this forum and I found a few answers that were kind of helpful yet confusing, I am able to boot into testmode with the download links that I found in the 2.1 version, I only downloaded the v1.4 and the update. Now I need to know what I have to do to make it work, preferably without too much confusion. Thank you for your assistance
Posted Aug 14, 2014 · 21:50 UTC#2
You're saying that it was working perfectly and, for no reason at all, it started to give you "No applicable program"? You didn't install HackMode or anything?
Perhaps what you can try is to install the latest firmware update. Maybe it will solve your problem.
Posted Aug 31, 2014 · 20:18 UTC#3
I think that they tried to install 2.1 but messed it up, where or how would I return it to factory?
Posted Sep 01, 2014 · 12:32 UTC#4
Some people apparently got lucky by removing power from the unit for 10 minutes. By "removing power", I mean disconnecting it completely from the battery (might be easier to disconnect the battery than removing the unit).
