just burn 1 file?
By Tosh · Mar 04, 2007in Custom Backgrounds💬 9 posts👁️ 1,993 views
Posted Mar 04, 2007 · 20:20 UTC#1
i'm saving my ISO that i edited as we speak, i just wnt to make sure that the only file i'm burning through NERO is the one that i edited? or do i have to burn the other 2 files that also were decrypted off of the NAV DVD. Thanks all!!!!!!!
-Tosh
Posted Mar 04, 2007 · 20:39 UTC#2
You just need to burn the 7GB image file that was created. Use Nero to "Burn an Image" to a dual layer DVD.
Posted Mar 04, 2007 · 21:16 UTC#3
does it HAVE to be dual layer? i just bought memorex DVD-R's pretty sure they're single layer.. :-\. Also when i'm saving my ISO image, i'm using MagicISO, it takes awhile to save cuz it's an enormous file, but it gets stuck on 50% when saving, i let it sit for like 5 or so minutes on 50% then i cancled it and retried but again still on 50%...is this normal? Thanks again
-TOsh
Posted Mar 04, 2007 · 21:18 UTC#4
Nope its not normal to freeze at 50%, and yes you need dual layer dvds, unless you delete vital POI files. How else would you burn a 7GB file to a 4.7GB single layer dvd?
Posted Mar 04, 2007 · 21:22 UTC#5
thanks fo the quick reply, i really dont' know what to do about this 50% freezing buisness starting to upset me just a bit. :-\ It's on 50% as i type this and has been for a few mintues. i don't know what to do!
Posted Mar 04, 2007 · 21:24 UTC#6
I use UltraISO, and when I change files around, it could take sometimes 15 minutes to save and close the ISO file.
Posted Mar 08, 2007 · 01:11 UTC#7
Do i have to have a Dual Layer DVD burner?? i hoope not :-\
Posted Mar 08, 2007 · 01:16 UTC#8
Yes, you need a DL DVD Burner. Unless you plan on deleting all the POI's.
Posted Mar 14, 2007 · 01:52 UTC#9
No, use your single-layer burner to burn on a dual-layer disc.
You're lucky I can't find a retard emoticon.
