What problems is everybody having with IOS 8
By philfrompa · Sep 20, 2014in NEX Series💬 19 posts👁️ 3,335 views
Posted Sep 20, 2014 · 15:05 UTC#1
I know Pioneer stated what is not working with IOS 8, but that seems to be mostly with App Radio.
I am interested in what problems others are having with the latest IOS with just the Head Unit.
Like Bluetooth, Maps, Phone, etc, before I upgrade.
I have the 5s iPhone and did not upgrade the software, and might not depending what others are going through.
At least not until Pioneer updates the Units.
Phil
Posted Sep 20, 2014 · 16:29 UTC#2
Music doesn't like to play and some times I have to start it on the phone to get it to work.
Bluetooth phone integration is really messed up. If it does work you can't really count on it.
I don't use app radio so not sure about that
I'm kinda bummed about the problems though.
Posted Sep 20, 2014 · 17:26 UTC#3
With my iPhone 6, I cannot hear calls through the NEX. Pairing is fine. It's like the phone connection is not going through the NEX anymore. The small "in call" screen does not even pop up on the NEX. On the iPhone, is shows that the sound should be coming from the AVIX8000NEX, but all I get is silence. I have to click on the iPhone option on the phone to start communicating.
Everything else seems fine. Texting with Siri through the NEX, phonebook download... Not sure if its iPhone 6 related or iOS 8. But, I was running iOS 8 GM with my iPhone 5 with no issues until I switched phones yesterday.
Posted Sep 20, 2014 · 18:14 UTC#4
I'm have zero issues with songs playing or Bluetooth on my 5s.
Maybe you have a bad iphone 6? I don't think it is on iOS 8 issue. Do all the resets you can and possibly swap out the phone? Apple Store have them in stock today so you may be able to swap.
Edited Sep 20, 2014 by Spankey
Posted Sep 20, 2014 · 19:12 UTC#5
I have no issues with iphone6, i just tried everything. Except appradio.
Posted Sep 20, 2014 · 19:18 UTC#6
iOS 8 on iPhone 5s
Pandora using cable works fine
Phone calls though Blue tooth works fine
Posted Sep 20, 2014 · 20:19 UTC#7
Did you do an iCloud restore or go ahead with a blank phone and add your apps?
Posted Sep 20, 2014 · 20:57 UTC#8
My iPhone 6 issues seemed to be related to my iCloud restore. Everything worked except the Bluetooth phone calls. No audio, or visual display on the NEX that a call was going through. After an erase and reset of the phone without the iCloud restore, I tested it out and it worked just fine.
Posted Sep 20, 2014 · 21:18 UTC#9
I backed up on mac mini, then restored iphone6 with backup using iTunes.
Posted Sep 20, 2014 · 22:11 UTC#10
I have a 6+ and I have had an issue with playing spotify via USB. Today my phone was connected, I turned my truck off and left the phone connected and when I turned my truck back on my NEX said "no device connected" and then the unit rebooted itself. I unplugged and plugged the phone in a few times and it wasn't recognized. Finally recognized it after a few tries.
Posted Sep 20, 2014 · 22:40 UTC#11
So far I have not run into any issues with my iPhone 6, however my experience is only limited with Bluetooth. I didn't particularly like AppRadio stuff, and I am really waiting for the CarPlay update to see how thing work out. I imagine Apple would ensure that CarPlay works properly with iOS 8, and that's pretty much what I want out of my NEX.
Posted Sep 20, 2014 · 23:25 UTC#12
Everything is working as before on my iPhone 6+.  I really don't use that much stuff though.  I generally just plug the phone into USB1 and play music using the steering wheel controls.  I did have one issue where the whole system got confused.  I got a phone call, unplugged the lightning cable, and answered the call.  After that, all sorts of stuff wasn't working right.  Next time I got in the car, it was all good.
Posted Sep 20, 2014 · 23:26 UTC#13
It seems most have the 5s and IOS 8 working fine with the head unit, not counting app radio, never liked that anyway. So I upgraded my 5s to the new ios and will check out the 7000 tomorrow.
Hopefully everything still works the same as before the update.
Phil
Plus if I check it now and it does not work right, I will be up all night with that on my mind.
Edited Sep 20, 2014 by philfrompa
Posted Sep 21, 2014 · 00:29 UTC#14
I read in a BMW forum that you had to just do a "reset all settings" and it fixes the Bluetooth issue. This reset does not remove any data from your phone. I tried it and it worked for me! Nex8000 iPhone 6
Posted Sep 22, 2014 · 00:14 UTC#16
I have an 8000 nex and and iphone 5 connected via usb. Everything is working as it did before the iOS8 update, but I seem to have an issue with audio playback from music stored on the phone. When I first get into my vehicle and connect my phone, whatever track I select to play begins playing ok. However, within the first 30-60 seconds the audio quality slowy degrades until it is complete garbage. It almost sound like the Lightning cable is bad. If I disconnect the phone and re-connect it, all is well and the playback resumes without any issue...... Weird.
Only happens on music stored on the phone, Pandora, FM, HD radio, etc are all fine
BTW, I shut all my apps and restarted the phone right after the iOS 8 upgrade.....
Edited Sep 22, 2014 by rtpjunior
Posted Sep 22, 2014 · 12:10 UTC#17
That's happened to me in the past. I usually just unplug the phone and reset the unit and all is fine. Not something I can say I have heard more than once.
Posted Sep 22, 2014 · 13:51 UTC#18
Did you reset the phone or the NEX?
Posted Sep 23, 2014 · 12:04 UTC#19
Still no problems, but I like the hey Siri feature, and she definitely understands me better
