Unit overheating?
By philfrompa · Sep 26, 2014in NEX Series💬 4 posts👁️ 1,133 views
Posted Sep 26, 2014 · 20:34 UTC#1
Has anybody had a warning come up that the unit is overheating and that it is going to shut down?
Mine did this and now won't start.
Phil
Posted Sep 26, 2014 · 21:35 UTC#2
Make sure the fan's airflow is unobstructed in the back of the unit.  If it is, check it and make sure it works.
Posted Sep 27, 2014 · 02:08 UTC#3
Yeah check the fan, I had the same problem and the cables were blocking the fan. It would run about 45 minutes to an hour then shut down. Once I pulled it and readjusted the cables it worked fine.
Posted Sep 27, 2014 · 11:36 UTC#4
Thanks guys, I will check that. I did start the truck up again last night and did see the unit come alive. I shut it down right away, didn't have time to look at it. But at least I know it is not toast.
Nice safety feature I guess,
Phil
