Is it worth installing CarPlay
By philfrompa · Oct 05, 2014in NEX Series💬 21 posts👁️ 4,079 views
Posted Oct 05, 2014 · 13:18 UTC#1
It seems as though most are not happy with the install of CarPlay and have been having all kinds of problems.
I am guessing that Pioneer or Apple will not address these issues very shortly.
So I am on the fence about even installing the update. I love my NEX 7000 the way it is, but still want CarPlay as an alternative function.
Once CarPlay is installed, do all the standard NEX functions still work as before, or does CarPlay affect these in any way?
Phil
Posted Oct 05, 2014 · 13:33 UTC#2
Can't play sd card in rear if u have CarPlay connected.
Edited Oct 05, 2014 by tekki
Posted Oct 05, 2014 · 13:34 UTC#3
As far as I can see, you can just use the iPhone with usb2 port and it will act just like it did without carplay.
I just hit the home button on the nex and I can operate the HU just like before the upgrade.
And if you're running Apple maps via carplay, you can switch back and forth via the home button on the nex.
Posted Oct 05, 2014 · 13:46 UTC#4
In my opinion, the biggest risk you take in installing CarPlay right now is that you might end up with the awful static popping problem. That's what happened to me: my unit worked fine before the update, and while I like having CarPlay, I do NOT like the fact that now every time I turn my car off there's a HUGE pop of static through my speakers. And it's happened to other people too.
So, given the chance to do it again, I might have waited to see if a fix for this problem would. forthcoming. But knowing Pioneer, that isn't very likely.
Posted Oct 05, 2014 · 13:58 UTC#5
This is my second 8000nex. Sold the first one after selling truck. But now that I have read all of your post, I'm definite waiting on installing an update. Not worth it right now to me. Especially the popping noise. Kind of seems like it would be aggravating. Ill prob keep the 1.02 for now.
Edited Oct 05, 2014 by kush1007
Posted Oct 05, 2014 · 14:12 UTC#6
From reading all of the comments, I believe that the popping noise is happening to a small number of people. It certainly is not happening to me. So far, The only negative for me is the more metallic sound I hear during a call through CarPlay. Everything else works for me.
What people have to keep in mind is the vast number of different configurations out there. I have an 8000NEX, using the factory speaker wiring through a F01 harness hooked up to a maestro RR. I do not have the HU hooked up to a separate amp for the front and rear speakers, but I do have a separate powered subwoofer.
It would be helpful for those having issues to list out their own configurations so we might be able to start troubleshooting these issues ourselves. .
Posted Oct 05, 2014 · 14:48 UTC#7
Good point @TheEdge! Im on factory Bose with Gmos lan 012. That module is a piece of work by itself!! :)
Posted Oct 05, 2014 · 14:52 UTC#8
@TheEdge are you geting the no resume on usb and sd card?
Posted Oct 05, 2014 · 15:44 UTC#9
Phil
I wouldnt because it completely crashed my unit. Now I more than likely have to send it back to pioneer. http://avic411.com/index.php?/topic/39561-5000-nex-not-updating-stuck-in-recovery/
Posted Oct 05, 2014 · 17:08 UTC#10
I also have front and rear speakers hooked up using stock wires and(no amp), and subwoofer(with amp). I do not have any popping noises, my music and ripped dvd both start where left off, on sdcard and ssd. I have had no issues whatsoever, just don't have any need for carplay, so i disabled it. I think the popping sounds the few people are hearing may be an amp issue.
Posted Oct 05, 2014 · 17:12 UTC#11
So is this an amp issue or what? This continues to happen to me and it happened again Friday.
trim.499000D7-8E4F-4C82-A017-BFA807E39AC0.MOV
Edited Oct 05, 2014 by EricVII
Posted Oct 05, 2014 · 17:21 UTC#12
Eric, i wish i could tell you a definitive answer on that. If all the guys that are having the issue could maybe list how their system is setup, maybe we all could see a common thing or something. I have read all your posts and feel your pain, I have been trying to figure out if is an amp issue or not. I do have one question, If you turn off all inputs before you shut down the vehicle, does it still pop?
Posted Oct 05, 2014 · 17:27 UTC#13
I have the popping issue, and my setup is as follows: head unit, JL XD700/5 external amp, subwoofer. In my setup, the front components and subwoofer are run off the amp while the rear speakers (which are hardly ever used) are run off the head unit itself.
Would be interesting to see if everyone who has the popping issue is using an external amp.
Posted Oct 05, 2014 · 18:47 UTC#14
Try hooking up amp turn on from the amp to acc instead of remote wire on the deck.
Make sure gain controls are set appropriately, no more than half way
Also may be blown pico fuse internally on the deck from plugging rcas in and out while everything was powered up
Edited Oct 05, 2014 by superjet
Posted Oct 05, 2014 · 18:53 UTC#15
I have tried everything from resetting the 8000 to trying every cord with the USB 1. It doesn't do it with the Bluetooth playing music, the radio, the cd, or even a USB flash drive. My only issue is when my apple products are plugged in with the USB 1 from the Lightning cord to the 30 pin cord from pioneer. IPod touch, iphone 5 when I had one, iPod classic, and I haven't tried with this iPhone 6 playing music. It happened again doing that Friday with my iPod touch which is updated to the iOS 8.0.2.
Posted Oct 05, 2014 · 18:59 UTC#16
That is what i am wondering.
Posted Oct 05, 2014 · 21:17 UTC#17
I have the popping issue and am using an external amp. I brought that up to Pioneer tech support and they dismissed that having anything to do with it because it doesn't happen on SiriusXM or other sources... but I don't think it should be discounted.
If you have updated and are having this issue or other issues, you can disable CarPlay under Smartphone Settings on the radio. This eliminates the pop, but returns you to pre update functionality.
Posted Oct 06, 2014 · 01:41 UTC#18
I have also experienced the popping issue and using 3 external amps - 2 pioneer 4 channels and 1 JBL mono.  I get the popping when playing audio shutting off vehicle.  I tried pausing the audio when I shut down vehicle and didn't get the pop.
Posted Oct 13, 2014 · 01:12 UTC#19
Yes!, waiting on both Waze and Pandora for Carplay.
My unit is the 8000, I have not noticed any issues after the update. I use a iPod classic for lossless music and audio books, the resume play functions properly.
If I had a SSD, the resume play disfunction would be enough reason to skip this update.
Edited Oct 13, 2014 by B1978J
Posted Oct 13, 2014 · 02:13 UTC#20
I have 480gb ssd and have no issue with resume, it took several on/off cycles and works flawlessly.
Edited Oct 13, 2014 by joemamma1954
Posted Oct 13, 2014 · 03:42 UTC#21
I have an 8000NEX with an iphone5 connected via a lightning to USB1 cable.  I have a Porsche with the factory Bose amplifier and speakers. I used a MOST adapter from the HU to the Bose amp.  All speakers, front,side and rear work.  I am still learning to use the features of both the 8000 and Carplay but everything I have tried works and there is no popping or other noise issues nor any resume problems. I use the Carplay for music now instead of the Pioneer ipod/USB1 function but both work fine.  The hands free phone via CarPlay works fine also.  Mine was installed in May and I have used it without Carplay since then but updated the firmware a few days ago to get CarPlay and have had no issues since. I have found AppRadio to be a poor product and have abandoned it. Otherwise good products.
