Hello folks, I am hoping someone has an idea on what is going on with my AVIC-Z1
I have the bypass in place and have been using my AVIC-Z1 unit since 2008.
Unit was upgraded with a Toshiba MK6034GAX drive and the Z3 2010 Maps
Everything has worked perfectly for years since the upgrade, however last week I started getting "Cannot use HDD" error messages. They seemed sporadic and would go away sometimes. Finally on start they became permanent, so I figured I have a bad upgraded HDD. I pulled it and ran diagnostics. All good, nothing wrong with it.
As a test I took the original 30GB Toshiba HD the unit came with and put it in. Same Result: "Cannot Use HDD"
At this point I am thinking there is an internal issue with the unit as the original HD should have worked, no?
Thoughts/Suggestions?
