TV Tuner?
By CHemi · Mar 05, 2007in General💬 10 posts👁️ 1,780 views
Posted Mar 05, 2007 · 14:40 UTC#1
Is the AVIC-D3 directly compatible with the Pioneer TV Tuner (5700)? Anyone know, thanks!
Posted Mar 05, 2007 · 16:09 UTC#2
No, there is no A/V bus on the D3
Posted Mar 05, 2007 · 16:55 UTC#3
Didn't think so, thanks for the confirmation!
Posted Mar 05, 2007 · 17:07 UTC#4
I guess that means the 6-disk DVD changer is NOT compatible as well, then...
Bummer... :(
Mark
Posted Mar 05, 2007 · 18:59 UTC#5
Well has anyone checked what you can use the AV inputs for?
Because on the D2, you can use the AV inputs for the DVD player and still control it through the IP bus.
Maybe Pioneer changed it so you can use the AV inputs on the D3 for the TV tuner and it can be controlled through the IP bus.
Posted Mar 05, 2007 · 19:02 UTC#6
Nevermind. I just looked at a pic of the D3's sources and TV tuner isn't one of them.
Posted Mar 05, 2007 · 20:26 UTC#8
It'll let you watch the tuner on your D3, but you wont be able to control it through the touchscreen. You'll need a remote.
Posted Mar 06, 2007 · 01:47 UTC#9
that cable is not worth $20. rat shack should have it
Posted Mar 06, 2007 · 02:01 UTC#10
You could use it anyway, just a bit more of a pain than with A/V bus. The DVD player already comes with a remote control, so just mount it somewhere within site of the remote and run it in standalone mode. Then run the audio and video out to the A/V input on the D3
Bummer... :(
Mark
