Carplay Disconnects
By Archieast · Oct 09, 2014in NEX Series💬 12 posts👁️ 2,652 views
Posted Oct 09, 2014 · 19:52 UTC#1
After successful upgrade to Carplay with iPhone 8.02 version Carplay works for a while fine with some problems with Spotify but after 10 minutes or 20 it suddenly disconnects and I have to unplug and re-plug to restart Carplay again. It is very annoying. Any suggestions?
Thanks in advance :)
Posted Oct 09, 2014 · 19:58 UTC#2
Sounds simple but have you rebooted / power cycled both the iPhone and NEX units?
Posted Oct 09, 2014 · 20:06 UTC#3
Yes I did and it did not work actually.
Posted Oct 13, 2014 · 00:58 UTC#4
Have you tried shutting down all unused apps on the phone? Rebooting the phone does not kill them. You must double tap the home button, then swipe the app to be killed towards the top of the screen.
I have no idea if it will help, but it will, at least, remove one possible cause.
Posted Oct 13, 2014 · 16:23 UTC#5
I have run into this as well.  The time seems to be very random.  I use my 30 minute drive home from work as a measuring stick - sometimes it works great and I don't have a problem and other times it "disconnects: 2-3 times.  When it happens the USB1 selection disappears as a selectable input.  As Archieast said, the only way it seems you can snap CarPlay back to life is to unplug my iPhone 5s and plug in back in.
FYI...have quit out of application and restarted my iPhone 5s multiple times.  Had hopes that the iOS 8.1 beta might address it and for a little while it appeared it did but over the weekend it disconnected again.
While I hope this is a fixable CarPlay issue, there is a small part of me that believes this might be something more.  I had less severe issues when I would run my iPod Classic using USB1.  Every once in awhile my iPod Classic would also "disappear" but in this case I could switch to another input, wait a "few minutes" and then USB1 would reappear again.  I chalked it up to using an old iPod Classic but maybe there is something going on with the USB1 connection that needs to be looked at closer.
Posted Oct 14, 2014 · 10:32 UTC#6
I have seen this as well. No solution as yet.
Posted Oct 15, 2014 · 20:07 UTC#7
8.1 beta 2 hosed CarPlay for me. Can't even use it anymore.
Posted Oct 15, 2014 · 20:33 UTC#8
Had a friend with almost same situation, we replaced the usb extension cable and used an apple certified lightning cable and it fixed his problem, careful not to bend the usb extension too much.
Posted Oct 15, 2014 · 21:15 UTC#9
I will try another usb extension cable then and let you know ...
Posted Oct 15, 2014 · 22:01 UTC#10
I will try this as well.  Fairly certain I am using an Apple cable but cannot vouch that I have not bent it "too much."  I will pay attention to that going forward...
...although with that said, CarPlay (8.1 beta 2) has worked well the last two days.
Posted Oct 17, 2014 · 20:50 UTC#11
I tried different Apple cables but no luck. It disconnects at different times. I guess we need to see how 8.1 will do :(
Posted Oct 17, 2014 · 21:30 UTC#12
Not using an Apple cable here (long Belkin though it is Apple certified) and mine is not disconnecting.
