Rollback firmware....rear cam problems
By sshams95 · Oct 23, 2014in NEX Series💬 5 posts👁️ 1,121 views
Posted Oct 23, 2014 · 13:19 UTC#1
On 1.07, my backup camera worked without fail.  Previously, it was intermittent.  Sometimes, I would just get a black screen.  But the problem went away on 1.07.
On 1.08, this problem is happening again.  On initial start, when backing out...it works fine.  But if I try it again, whether it be holding the maps button or backup up again...I get the black screen.
I want to confirm that this is a software issue.
How can I rollback to 1.07?  Is it simply a matter of updating via SD card, or do I need to do a factory reset?
Posted Oct 23, 2014 · 13:20 UTC#2
I'm not sure rollback is possible. I know that after 1.06 came out, Pioneer said it was impossible to go back to the firmware before it.
Posted Oct 23, 2014 · 13:40 UTC#3
Im having issues with back up cam. But i think mine is coming from using factory cam linked to reverse light power instead of switched power. Are you using a aftermarket cam or factory. I noticed on the 1.06 release notes it says to use a aftermarket cam.
Posted Oct 23, 2014 · 13:54 UTC#4
I'm using an aftermarket Kenwood.  I wanted to verify if it's software related before going back to installer to recheck connections.
Posted Oct 23, 2014 · 14:39 UTC#5
My 3rd-party license plate frame camera has worked flawlessly with the original firmware and the two carplay updates.
