Is it necessary to install the back up wire?
By audilover08 · Mar 06, 2007in General💬 9 posts👁️ 1,634 views
Posted Mar 06, 2007 · 03:12 UTC#1
I was just curious if you had to install the reverse and speed sensor wire...?
Posted Mar 06, 2007 · 03:35 UTC#2
nope, not necessary
Posted Mar 06, 2007 · 03:42 UTC#3
You should if you can, especially the speed sensor.
The reverse wire isn't really going to hurt anything unless you have a backup camera or plan to do a lot of driving in reverse.
The speed sense on the other hand will enable 3D navigation, vehicle stats and still allow you to Navigate even when GPS Signal is unavailable.
Posted Mar 06, 2007 · 03:47 UTC#4
I am going to install mine to the speed wire but not the reverse. I did get a back up camera but do not want the camera coming on every time I put it into reverse. Most of the time I wont need it.
Posted Mar 06, 2007 · 04:13 UTC#5
Ummm... then whats the point? Its a backup camera. Meant to go on when you backup. It makes it easier to backup.
Posted Mar 06, 2007 · 04:17 UTC#6
I heard if you install the backup wire when you shift into Reverse your AVIC blows up! :D
Posted Mar 06, 2007 · 14:10 UTC#7
Because most of the time I am just backing up and have alot of room. I would rather control it when I need it. May change my mind later.
Posted Mar 06, 2007 · 15:48 UTC#8
I dident connect mine. in the D3 you can manually turn on the back up camera.
Posted Mar 06, 2007 · 15:54 UTC#9
For all the Pioneer GPS units you can manually turn them on. It is just a matter of convenience.
