Large Album Art Not Showing After 1.06/1.08 Updates 5000NEX
By Mengels7 · Nov 05, 2014in NEX Series💬 25 posts👁️ 4,166 views
Posted Nov 05, 2014 · 00:45 UTC#1
Before the CarPlay update, I had no issues with my iPhone 5 or 6's album art showing in the music player. After the CarPlay update, I often choose to disable CarPlay due to it being a glitchy, crashing, piece of shit. I've noticed tons of album art not loading now in the regular music player, and it seems to all be art that I've custom picked for the albums in very high resolution. All the stuff at a reasonable resolution or downloaded by iTunes works no problem. Anyone else having this issue? Any solutions? Is there a good way to submit a bug report to Pioneer? I love album art and this is depressing to me :(
Posted Nov 05, 2014 · 01:44 UTC#2
Haven't noticed this issue, and my CarPlay works just fine.
Posted Nov 05, 2014 · 04:17 UTC#3
These head units do not like album art that is over 600px in either dimension -- mine never did, even with original factory firmware.
Posted Nov 05, 2014 · 05:00 UTC#4
Mine used to have no issue with the larger stuff, but I think iTunes downloads it at 500x500 so it sounds like that's the limit for me. Thanks.
Posted Nov 05, 2014 · 18:39 UTC#5
Other than on a display with greater than 600 pixels vertical (computer monitors, some tablets mostly), 600 x 600 album art stored in the media file just serves to bloat the file.
On the NEX units, you're only going to see maybe 360 x 360 pixels (guessing).  That means a 600 x 600 image has to be downsampled to display it... and if you talk to any digital image guru, you will realize that a downsampled image is less pristine in appearance than one created at the size it is displayed.  In fact, say you wanted to store a 360 x 360 image in the file but only have a pristine 600 x 600, you would have to shrink it in an image editor... and the gurus recommend applying an "unsharp mask" filter to the shrunken-size image to [somewhat] restore image clarity.
(If you are a guru reading this, please disregard any misuse of terminology :))
FWIW, you can store more than one image in image-embed-able media files, including the same image at different resolution... but I have no idea how to tell any media player which one to display.
Posted Nov 06, 2014 · 00:48 UTC#6
Understood, it's just that with phone becoming higher and higher resolution, I like to future-proof with super high resolution artwork when iTunes doesn't automatically find it.
Posted Nov 06, 2014 · 15:44 UTC#7
I can relate to that :)
Posted Nov 08, 2014 · 04:24 UTC#8
Figured it out. Sort of. It happened to coincide with me installing those updates and switching to my 128GB iPhone 6, but none of that was the cause.
I started re-ripping my older albums in Apple Lossless in iTunes. The way iTunes associates album art with ripped Apple Lossless files by default doesn't work with most other applications. All of the albums I had issues with on my NEX unit were ones I had recently ripped.
Adding custom art to some of these helped, some actually needed me to get the art from iTunes. Had to do with tagging or something. It's honestly all beyond me. I made UK and Japan iTunes accounts just to get working album art for two of the albums. Point is, I guess it had nothing to do with the file size.
Posted Nov 08, 2014 · 06:31 UTC#9
ITunes in my experience is very sketchy about embedding album art work in iTunes-ripped files.  When you use "Get Album Art" for missing art, more often than not it downloads to an album art folder and internally associates with the file... it does not embed the art.  It's fine until you play the file on another player..."Where's the album art???"  I found a vbs script that embeds the art for windows.
Here's the script text:
' # itunes_insert_artwork.vbs
' # This script will tag your files using artwork downloaded using iTunes 10
' # written by: Robert Jacobson (http://teridon.googlepages.com/itunesscripts)
' # Last Updated: 30 Jan 2012
' # Version 1.1
' # Modified version and fixes discussion at following link:
' # http://sheerboredom.net/2010/10/11/embed-album-artwork-from-itunes-into-mp3-files/
' # This script is GPL v2.  see http://www.gnu.org/copyleft/gpl.html
' # Use option "-k" to keep the artwork files extracted
' # (in the same location as the song file)
' # (the default is to remove the files)
' # Special Thanks to http://www.facebook.com/jrsousa2 for the error checking fix!
Option Explicit
Dim iTunesApp        ' iTunes.Application object used to access the iTunes application.
Dim tracks           ' The tracks collection object of the Library object.
Dim TrackPath        ' The path to the track
Dim ArtPath	         ' The path to the artwork
Dim i                ' A counter variable.
Dim Msg              ' A string for a message.
Dim f                ' A file object.
Dim sources
Dim source
Dim playlists
Dim playlist
Dim playlistName
Dim j
Dim m
Dim c
Dim songName
Dim artist
Dim result
Dim listarray
Dim num
Dim k
Dim track
Dim numtracks
Dim FormatArray(4)
Dim ExtArray(4)
Dim Artobj
Dim Art
Dim ArtDir
Dim Format
Dim BasePath
Dim fso
Dim NumFiles
Dim KeepFiles
Dim args
Dim arg
Dim IsDownlArtw_value
Dim erro_no
Dim erro_desc
Set fso = CreateObject("Scripting.FileSystemObject")
FormatArray(0) = "Unknown"
FormatArray(1) = "JPEG"
FormatArray(2) = "PNG"
FormatArray(3) = "BMP"
ExtArray(0) = "unk"
ExtArray(1) = "jpg"
ExtArray(2) = "png"
ExtArray(3) = "bmp"
Set iTunesApp  = CreateObject("iTunes.Application.1")
Set sources = iTunesApp.Sources
Dim vers
vers = iTunesApp.Version
Dim Reg1
Set Reg1 = new RegExp
Reg1.Pattern = "^11"
if Reg1.Test(vers) Then
	' yay
Else
	Wscript.Echo "This script requires iTunes 10"
	Wscript.Quit
End If
KeepFiles = False
Set args = WScript.Arguments
' Scan command line arguments
For Each arg in args
  ' Is it a flag.
  If Instr(1, arg, "-", 1) = 1 or Instr(1, arg, "/", 1) = 1 Then
    ' Check for list flag
    If UCase(arg) = "-K" or UCase(arg) = "/K" then
 KeepFiles = True
    End If
  End If
Next
For i = 1 to sources.Count
	Set source = sources.Item(i)
	IF source.Kind = 1 Then
		Set playlists = source.Playlists
		Wscript.Echo "Select from the following playlists" & chr(13) & chr(10)
		Wscript.Echo "Number of playlists: " & playlists.Count
		For j = 1 to playlists.Count
			Set playlist = playlists.Item(j)
			playlistName = playlist.Name
			Wscript.Echo j & ": " & playlistName
		Next
		Wscript.Echo ""
		Wscript.StdOut.Write "Enter comma-separated lists to process: "
		result = WScript.StdIn.ReadLine
 		listarray = split(result, ",")
 		For k = 0 to UBound(listarray)
 			num = listarray(k)
 		   	Set playlist = playlists.Item(num)
 		   	Wscript.Echo ""
 		   	Wscript.Echo chr(9) & "Processing playlist " & num & ": " & playlistName
 		   	Set tracks = playlist.Tracks
 		   	numtracks = tracks.Count
 		   	Wscript.Echo chr(9) & "tracks: " & numtracks
 		   	NumFiles = 0
 		   	For m = 1 to numtracks
 		   		If m > tracks.Count Then Exit For
 		   		Set track = tracks.Item(m)
 		   		'Wscript.Echo "num: " & numtracks & " Count: " & tracks.Count & " m: " & m
 		   		If track.Kind = 1 Then
 		   			songName = track.Name
 		   			artist = track.Artist
 		   			TrackPath = track.Location
 		   			Set Artobj = track.Artwork
					For c = 1 to Artobj.Count
						Set Art = Artobj.Item(c)
						On Error Resume Next
						if Art.IsDownloadedArtwork Then
							'On Error Resume Next
							IsDownlArtw_value = Art.IsDownloadedArtwork
							erro_no = Err.Number
							'Err.Clear
							erro_desc = Err.Description
							If Err.number <> 0 Then
								IsDownlArtw_value = False
							End If
							if IsDownlArtw_value Then
							Format = Art.Format
							End If
							'Wscript.Echo "Format is " & FormatArray(Format)
							ArtDir = fso.GetParentFolderName(TrackPath)
							'Wscript.Echo "Artdir is " & ArtDir
							'ArtDir = fso.GetBaseName(ArtDir)
							Dim RegX
							Set RegX = new RegExp
							RegX.Pattern = "[/:\\\*\?""""<>]"
							RegX.Global = True
							songName = RegX.Replace(songName, "-")
							'songName = Replace(songName, "/", "-")
							ArtPath = fso.BuildPath(ArtDir, songName & "." & ExtArray(Format))
							Wscript.Echo "artpath is " & ArtPath
							' save to file
							Art.SaveArtworkToFile(ArtPath)
							' insert from file into track tag
							Art.SetArtworkFromFile(ArtPath)
							if (KeepFiles) Then
								' nothing
							Else
								fso.DeleteFile(ArtPath)
							End If
							NumFiles = NumFiles + 1
						End If
					Next
 		   		End If
 		   	Next
 		   	Wscript.Echo NumFiles & " files processed in playlist " & playlistName
 		Next
		'End If
	End If
Next
As I recall, I modified one line so it works with iTunes 11.  If you want to run it, just copy the above text into Notepad and save it with a .vbs extension.
Supposedly there's an script out there that'll do the same on Apple computers.
Posted Nov 08, 2014 · 15:37 UTC#10
' # Version 1.1
Option Explicit
Dim sources
Dim source
Dim playlists
Dim playlist
Dim playlistName
Dim j
Dim m
Dim c
Dim songName
Dim artist
Dim result
Dim listarray
Dim num
Dim k
Dim track
Dim numtracks
Dim FormatArray(4)
Dim ExtArray(4)
Dim Artobj
Dim Art
Dim ArtDir
Dim Format
Dim BasePath
Dim fso
Dim NumFiles
Dim KeepFiles
Dim args
Dim arg
Dim erro_no
Dim erro_desc
ExtArray(0) = "unk"
ExtArray(1) = "jpg"
ExtArray(2) = "png"
ExtArray(3) = "bmp"
Dim vers
Dim Reg1
	' yay
Else
	Wscript.Quit
End If
KeepFiles = False
  ' Is it a flag.
 KeepFiles = True
    End If
  End If
Next
		Next
		Wscript.Echo ""
 			num = listarray(k)
 		   	Wscript.Echo ""
 		   	NumFiles = 0
							'Err.Clear
							End If
							Format = Art.Format
							End If
							Dim RegX
							RegX.Global = True
							' save to file
							if (KeepFiles) Then
								' nothing
							Else
							End If
						End If
					Next
 		   		End If
 		   	Next
 		Next
		'End If
	End If
Next
Wow! If it continues to give me issues I'm definitely going to give that a shot. Thanks so much!
Posted Nov 08, 2014 · 15:45 UTC#11
I just noticed iTunes 12 is out (downloaded and installed).  As I mentioned elsewhere, iTunes has more updates than any other software on my computers... and that include OS updates from MS!!!
Anyway, as I understand it, the script posted above will have to be modified to run with iTunes 12 installed.... but I am not a script guru.  All I can say is the script I posted above worked for me with iTunes 11.
To modify the script for iTunes 12, find the line...
...and change to...
Reg1.Pattern = "^12"
Also, I noticed earlier there's another line related to this.  Only makes a difference on version error.
Find, a few lines below the one above...
...and change to...
    Wscript.Echo "This script requires iTunes 12"
Posted Nov 08, 2014 · 16:24 UTC#12
Also just ran across this piece of shareware.
http://www.maximized.com/shareware/icoverart/index.htm
As shareware, it'll only do 5 songs at a time until registered.  Only $5 to register.
Haven't tried it, so if anyone does, please report your findings...
Posted Nov 11, 2014 · 23:26 UTC#13
No tools needed. Open up iTunes > select song(s) > Right-click > Get Album Artwork
iTunes 11 for Mac: Add artwork to songs and other items
http://support.apple.com/kb/PH12161
Edited Nov 11, 2014 by donmontalvo
Posted Nov 12, 2014 · 17:02 UTC#14
That does not EMBED the artwork in the file.  It just stores the artwork as a file in a separate iTunes "Artwork" folder and links it to the song file in iTunes.  That works fine in iTunes... but doesn't help at all for other media players.
To give you an idea what I'm talking about.... https://www.google.com/webhp?#q=embed%20artwork%20itunes
Edited Nov 12, 2014 by jhren
Posted Nov 12, 2014 · 21:50 UTC#15
Yep -- the NEX units will not look in the folder for artwork files (which is stupid and wasteful); to display the artwork must be in EACH music file individually as a tag. Yes, this means if you have 20 songs in an album you must consume 20x the album art in disk space, but since music is rather large compared against these art files it's not as bad as it initially sounds.
Posted Nov 12, 2014 · 23:44 UTC#16
My apologies I didn't realize this was happening. The latest iTunes versions make embedding artwork tougher, BeaTunes has some active threads on this. Sorry, I'll see myself out. :)
Posted Nov 13, 2014 · 00:07 UTC#17
If you want to embed the artwork in iTunes you can right click on one song and Get Info. Click on the artwork and right click and copy the image. Highlight all songs for a given album and right click and Get Info again. Delete the album image and paste the copied image and apply. This will embed the image onto the individual files.
Posted Nov 13, 2014 · 01:03 UTC#18
I've read that one on various sites.  Okay let's say I can... IDK as I really don't embed artwork in iTunes itself.  So I've already did the Get Album Artwork feature.
1) How do I tell which song files have embedded artwork and which ones do not...???  Let's say I have around 20,000 songs in my library and through previous work, perhaps 15,000 have embedded artwork.
2) Provided a response to 1) is viable, how long do you think it would take to do the remaining 5,000 songs?
FWIW, the script I posted earlier did not work for me with iTunes 12, after revising as suggested.  I tried the Maximize iCovertArt app.  It worked for 5 songs.  It may have let me do another 5 songs at a time, after restart, but it scans all the iTunes files on start up... taking several minutes to complete.  I paid the $5 registration fee, and am awaiting the unlock code via email.
Posted Nov 13, 2014 · 01:48 UTC#19
There is a script that will embed artwork but it is more miss than hit. The easiest way to find out is to export your files onto a sub and play them back. No artwork if the music isn't embedded. Artwork will show on iPhonesplaying through the music app if it is not embedded and in most cases the artwork will download if not there.
http://dougscripts.com/itunes/scripts/ss.php?sp=reembedartwork
Edited Nov 13, 2014 by Spankey
Posted Nov 13, 2014 · 04:16 UTC#20
For what it's worth, despite everything said here, the only way to get some of my ripped albums to show album art on my head unit was to get the album art from iTunes. Even if it meant making an entirely new account for a different region. I'm ripping in AIFF now and hopefully that stops this issue.
Posted Nov 14, 2014 · 12:18 UTC#21
I subscribe to iTunes Match, and I've made it a point to delete/re-download all my music. Even stuff that I did not buy from the Apple iTunes store. $24 yearly fee to keep my music sanitized is worth it to me. The tunes all come down with artwork, but none of the artwork shows in CarPlay. I agree with previous poster's concern, having to embed artwork is silly. Hope the bug report I submitted to Apple gets a prompt response.
Carplay Album Art Issue
http://avic411.com/index.php?/topic/39802-carplay-album-art-issue/&do=findComment&comment=286615
Posted Nov 14, 2014 · 19:50 UTC#22
... Hope the bug report I submitted to Apple gets a prompt response.
I'll hope along with you... but given the longevity of the problem, I will not hold my breath until resolved :)
Posted Nov 14, 2014 · 19:57 UTC#23
Apple doesn't frequent the forums, but they do respond to bug reports. They have to manage their cycles, so not sure where this falls under their priority list, but at least this gets it on their radar. :)
Posted Nov 14, 2014 · 22:06 UTC#24
I am not sure of your setup, but my album artwork looks fine on CarPlay playing from my iPhone 6. I also use iTunes Match.
Posted Nov 14, 2014 · 22:16 UTC#25
I just migrated to a new MacBook Pro Retina and my library metadata got hosed (I didn't use Migration Assistant). So my ratings, number of times each track was played, etc., got lost along the way, and I ended up with a bunch of duplicates.
The duplicates are resolved, and as of yesterday I re-enabled iTunes Match. So my library has to re-sync to the iTunes Match servers. I'm guessing it'll take a few days for that to complete. Then I'll need to re-sync my iPhone 6. Then I can test again and report back.
