Cannot get Bluetooth Audio after 1.08
By rsday75 · Nov 10, 2014in NEX Series💬 5 posts👁️ 897 views
Posted Nov 10, 2014 · 16:32 UTC#1
Hi,
I have updated to 1.08, and if I switch off USB connection for my iPhone and enable Bluetooth, I get Pandora, but the Bluethoth connection is dithered, and I cannot select it.
I was able to do this before. I would use the Bluethooth connection for Tunein, Slacker, etc. when on short trips when I did not want to plug the phone in.
Any ideas?
Posted Nov 10, 2014 · 19:10 UTC#2
Remove old connections in the phone and HU , also the name of the phone should not have spaces or punctuation.  See if those help
Posted Nov 10, 2014 · 23:50 UTC#3
Yeah. I just call my phone iPhone for name. I removed from the 4000 and forgot the 4000 on my phone. Same results. Pandora and aha work OK, Bluetooth is dithered.
Also, I notice that when the phone is connected Bluetooth, in FM, the station info is very dim. Looks fine when USB is active, but if the phone is connected and I choose FM, the station info is dim. Odd.
Seems this firmware has bugs. Sigh. I'm not pleased.
Posted Nov 11, 2014 · 01:19 UTC#4
Hi,
Any ideas?
You using car play while doing this? if so Bluetooth is disable.
Posted Nov 11, 2014 · 03:04 UTC#5
No, I switched back to Bluetooth. I have the smartphone connection set to Bluetooth.
