Can AVIC-5000NEX use the car's OEM microphone (2014 Honda CR-V)?
By donmontalvo · Nov 16, 2014in NEX Series💬 17 posts👁️ 11,475 views
Posted Nov 16, 2014 · 23:59 UTC#1
As others have mentioned on this forum, folks I who I talk to while driving are saying the audio quality isn't what it used to be.
Before I had the AVIC-5000NEX installed, all calls were handled over Bluetooth, using the OEM microphone.
The OEM microphone is in the center roof console, I wonder(ed) if quality would improve if the AVIC-5000NEX could use it?
Currently the microphone that came with the unit is positioned by the gas gauge.
Posted Nov 18, 2014 · 23:41 UTC#2
No i highly doubt it. Most OEM mics are integrated into the factory radio harness.
Posted Nov 19, 2014 · 23:05 UTC#3
I'm using the OEM mic from my 09 Civic with a 7000nex.  This is the same mic found in the 14 CR-V.
In order do so I cut the mic wires at the 28 pin Handsfreelink module connector and added a mini jack from Radio Shack to those wires.
Works great and I'm told it sounds better than the Pioneer mic.
Posted Nov 19, 2014 · 23:55 UTC#4
@RRSpikes that's what I was hoping to hear. When I asked the techs at the shop I usually go to, they explained it's just a matter of knowing which wires do what and wiring accordingly. I'll point the tech to this thread, thanks so much for confirming! :D
Posted Nov 20, 2014 · 19:19 UTC#5
No problem always glad to help when I can.
The required jack is a 2.5mm mono type.
I'm sure your wire colors at the Handsfreelink module will be different colors, but for anyone else wanting to use the Honda OEM mic in a Civic or CR-Z can do so by using the following pins at the Handsfreelink 28 pin connector.
09-11 Civic: pin 13 (yellow +) and 14 (brown -) Pin 12 is shield.
11-12 CR-Z:  pin 1 (blue +) and pin 2 (pink -) Pin 3 is shield.
Posted Nov 21, 2014 · 00:51 UTC#6
CR-Z 2011/2012 Service Manual has it the other way around...
Cavity    Wire Color    Name
   1              PNK         MIC–
   2              BLU         MIC+
I have a 2013 CCR-Z and as best I recall, everything regarding the audio and nav systems is unchanged from '11/12.
Posted Nov 21, 2014 · 16:53 UTC#7
   1              PNK         MIC–
   2              BLU         MIC+
You Sir, are correct.
...I should have double checked instead of relying on my memory when I replied.   The 7000 I have now replaced a 2011 CR-Z navi system I had previously installed in my 09 Civic.
The only differences I'm aware of between the 11/12 & 13/14 CR-Z (in regards to the navi systems) is that the 13/14 has the BT music profile activated in the HFL module and the navi head unit is made by Mitsubishi instead of Alpine.
Posted Nov 25, 2014 · 01:53 UTC#8
I just got back from the shop and I'm disappointed. The tech said the posts on this forum don't mention CR-V.
At first he said it was not possible, but I can't accept that - it's more professional to say "I don't know of a way".
If there is any way possible to use the 2014 CR-V's built in mic, I would love to do so, hoping more folks post answers.
Posted Nov 25, 2014 · 15:04 UTC#9
Can you take a pic of your 14 CR-V HFL 28 pin connector and post it?
The pic below is the 28 pin connector from an 09-11 Civic.  If you look closely, you'll notice that molded into the connector is pin 1 on the upper right.  My Civic schematics show this as being pin 14 while my 11-12 CR-Z schematics show it as being pin 1.  In a nut shell, pins 12, 13, 14 are the same as pins 3, 2, 1.
Because your 14 CR-V uses the same 28 pin connector that Honda/Acura has been using for at least a decade now, and the 12-14 CR-V HFL module has TAO (fist used in the Accord) in the part number, I'm willing to bet the mic pins (and the other pins too) are the same.
Posted Nov 27, 2014 · 01:49 UTC#10
Another option is to drop the ambient light & microphone module and connect there to the microphone itself, leaving the harness to it unplugged.  I believe the module itself is identical to the one I got in my CR-Z... just the housing that it goes into is different.
That's just a thought/suggestion.  In my case, I was dealing with a Kenwood DNN990HD and had no idea whether the OEM mic was even compatible.  I pulled the OEM mic out of the module and plopped the one furnished with the HU in it's place.  Haven't tried it yet though.  I've had it installed for over a year now and keep saying I'm going try but you can see how that's going... and the DNN990HD even has voice command capability (by itself, in addition to phone).
Posted Nov 27, 2014 · 03:01 UTC#11
My apologies, the work was already done. If I saw this sooner I could have asked for the tech to take an image.
The tech moved the microphone over to the rear view mirror, seems to be not as bad as where it was by the instrument cluster area.
Posted Dec 11, 2014 · 14:09 UTC#12
Following on donmotalvo's effort, I am trying to find out where my OEM bluetooth signals might be located on my CRV 2014 EX-L
Any ideas?
Here's a picture of my 28-pin connector.
Thanks in advance.
Edited Dec 11, 2014 by dogzipp
Posted Dec 11, 2014 · 15:08 UTC#13
Any ideas?
Thanks in advance.
That's not the HFL connector. Just a guess but that looks like the 20 pin radio connector.
Posted Dec 11, 2014 · 16:58 UTC#14
The OEM radio had 3 plugs on the back. Is the HFL any of those? Or am I looking for the Blueetooth unit, that one that they say it's behind the Shifter somewhere?
Posted Dec 11, 2014 · 17:56 UTC#15
I have an AVIC-5000NEX and an iDataLink Maestro RR, and combined all the radio features are working fine.
Is the HFL module a separate module that enables i-Mid control? If so I'd like to get with my shop to see about ordering/installing it.
PS, thanks for this info!
Don
Posted Dec 12, 2014 · 14:45 UTC#16
There are mic wires going to the radio but they're not the ones you need. You need to find the HFL (Bluetooth) module.   Carefully remove the shifter garnish to locate it.
Posted Dec 12, 2014 · 15:23 UTC#17
Don
Info from the HFL is used for the iMid.  It is handled by pin 25 of the HFL connector and is a B can function.  Your HFL module was disconnected when your 5000/MRR was installed.
Unfortunately, there is no aftermarket module (that I'm aware of) for Honda's with Pioneer radios that allows us to keep 100% of the functions we had with our original radios.  You lost some iMid info, I lost the ability to control my automatic climate control via voice.
I'm curious as to why your installer used the MRR with your 5000.  The MSW would have provided the same functions as the MRR at almost half the cost.
