I find this funny because after setting up my 8000 and running the system through a pink noise and time alignment I realized just how screwed up this unit is compared to some of my pro processors like my DBX Driverack 260 that I use in commercial sound.
What I find odd is the manual states that after pinking the system the EQ will return to Flat (which it did not it stayed on Powerful), it's also odd that the unit doesn't display the new curve into either Custom 1 or Custom 2 for you to see what the environment looks like post processing.
The funniest thing however were the calibrations that were determined during the ping tests to do distance alignments, in my case (see image below) it calculated that my front speakers were 100+ inches and rears were 90+ inches from the microphone which was placed hanging down from the latch that holds my removable top in place, here's the kicker, this was in a Vette where the actual distance was no more than 30 inches in any direction! I guess I could divide the numbers by 3 and enter them manually but what's the point. So either Pioneer is using mm's or cm's and attaching a label of inch to the results or their algorithms are really screwed up!
Bottom line I wanted to see how this would work, glad I did but in the end and quite honestly, I'll forgo the processing which amounts to nothing more than playing with crossover points and removing bottom end and do an alignment with the best tools I have at my disposal, my ears! TA and Pinking is a must for my commercial systems but at this level, it's more of a joke than anything. Nice try Pioneer.
