AVIC Z-1 and Cingular 8525 Connectivity
By Truvisions · Mar 06, 2007in Problems/Troubleshooting💬 10 posts👁️ 1,637 views
Posted Mar 06, 2007 · 07:51 UTC#1
Hello,
I have been looking at several posting and didn't see anything. Has anyone been able to get the Cingular 8525 to work with the Z-1. I had an unlocked QTEK 9100 and it worked fine. I just upgraded and the unit does not recognize the phone. I finally get the unit to see the device but then the password is not accepted. I also get the blue X over the icon on the top right. Can anyone shed light on this issue. I want to know if I need to do do something special to make this thing work.
Posted Mar 06, 2007 · 08:26 UTC#2
I played around with the sequence I was pairing the device. I put the phone in discovery mode. It found the NAV system but then when it asked for the password, I then went to the NAV and selected the option to register by phone. Then I went back to the phone and put in the passkey.
Posted Mar 06, 2007 · 18:05 UTC#3
I have the 8525. I was able to pair the 2. It goes in and out but it pairs. Also the echo is awful. Even after the upgrade so not sure if the phone is the cause or not. I paird it from teh phone had the phone discover the NAV. and yes had to enter in the passphrase...
Posted Mar 07, 2007 · 12:49 UTC#4
I have the 8125 (previous version of the 8525) and it works fine....
Posted Mar 10, 2007 · 11:42 UTC#5
Ok, 03...how did you pair your phone and Z1? I have an 8525 and got it to pair, no problem, but the blue tooth will drop out after about 2 minutes into the call. It will then hook back up again after the call has ended...then will drop again. I got it to not drop a call one time but that was it. It's frustrating getting it to work only to have teh call drop out in the middle. When the BT drops, I can pick up the handset and the call is active on teh handset. This does not happen with my handsfree headset I use in my other car.
Jay
Posted Mar 10, 2007 · 14:23 UTC#6
I didn't do anything special...just did it like the instructions tell you to...I've had no problems..maybe a difference in the BT software version in the phone :shrugs:
Posted Apr 21, 2007 · 11:26 UTC#7
Damn, I figured you'd say something like that. Maybe I'll reset and repair the phone. Mine works great, no echo even without the cd fix....if I could just fix the dropping issue, it would be perfect.
Jay
Posted Apr 21, 2007 · 16:49 UTC#8
I also had a terrible echo problem when I paired my 8525 and Z1.
Even when upgrading to WM6, the echo was still there. But there is a known problem with the Bluetooth Stack, so the echo wasn't a surprise.
Posted Apr 22, 2007 · 23:47 UTC#9
Hello
I have connected the 8125 to a Z2 without problem/
Posted Apr 22, 2007 · 23:47 UTC#10
Hello
