Can you change startup image on the Z1?
By Rodge · Mar 06, 2007in Custom Backgrounds💬 6 posts👁️ 1,700 views
Posted Mar 06, 2007 · 18:39 UTC#1
yo.....
I'm a little confused on if you can change the startup image on the Z1.. Can you? if so, how?
Does this require me to remove the HDD and hook it up to my computer?
any help would be appreciated, thanks
ALSO NOTE: My Z1 didn't come with any discs of any sort, everything is apparently preloaded on it.. is that how it's supposed to come?
Posted Mar 06, 2007 · 19:45 UTC#2
yes you have to connect hd to pc and unlock then you can modify the files.. yes your z1 came as it should with no disks and map info loaded on hd already
Posted Mar 06, 2007 · 21:12 UTC#3
thanks dude... Any info on what I'll need to do that? Hardware wise? software wise?
Posted Mar 06, 2007 · 22:00 UTC#4
check out the z1 hacking section, theres an adapter for laptop drive to ide youll need to.
Posted Mar 06, 2007 · 22:32 UTC#5
According to the Z2 manual you will be able to change the splash screen. So maybe the anticipated software update will include this feature. I think I am going to wait and see.
Posted Mar 07, 2007 · 00:03 UTC#6
sounds a lot better tahn unlocking your hard drive.
