D3 on 06 F350..95% installed..need help on other 5%
By packnheat · Mar 06, 2007in General💬 5 posts👁️ 1,016 views
Posted Mar 06, 2007 · 21:35 UTC#1
I'm 95% done installing D3, first timer..now if I can get help on the other 5% I'd be set...@ questions...
Crutchfield didn't send me a dash kit for the d3 to fit in my dash..after reading install manual i figured i didn't need it..The D3 is either to far in or out when I put the dash back together..do I need to go out and get the dash kit?
Last?..My truck has the feature that when you turn the ignition off the radio stays on for a while..is it normal for the D3 to change stations while this function is occurring and shut off when I open the door?, or should the D3 function just like the stock?..
PS..I hadn't preset staions when this occurred..
Posted Mar 06, 2007 · 21:38 UTC#2
I have a 06 Zephyr and that function works fine.
I did not have to do anything in particular, the line that gets the power to the receiver is tied to a switch when the door opens it kills the power unit turns off.
I would check wiring harness connections.
It should not randomly change tuner channels.
Posted Mar 06, 2007 · 21:39 UTC#3
Posted Mar 07, 2007 · 01:26 UTC#4
Yes get a kit for the truck. Makes it look factory. As said before no the avic should not be changing stations randomly. you have a steering wheel control interface installed?
Posted Mar 07, 2007 · 01:50 UTC#5
Thanks Gents..Got it all buttoned up and I most say, "this thing is the shiznitz"...thing is awesome...ipod video and functions are great, the bypass works perfectly, and bluetooth btb100 works fine...Thanks to this site and you guys.. :D
PS..yes I have the steering wheel control, amazingly programmed it on the first try...after reseting the D3, it no longer changed stations after turning teh ignition off.
