jvcjbl said:
Hey all,
I just install my AVIC-Z1 monday and love it to death. My one gripe is I am in the fastest growing city in the us and everything is changing... I have certain places (school and work) that are older than 2 years and not on the map system at all. Is there any update out there or one planned? Also, is there a way to train the voice commands for certain operations... I cant get the "AV Operation" to work... it just wont recognize the command.... "Basic Operation" works.... strange....
Jason
Pioneer is not that good about keeping everything up to date. They are doing better than Eclipse, Alpine, and Kenwood but it's still not that good. On the other hand, unless you are using XM NavTraffic, you probably shouldn't need directions to school and work unless you have bad memory. As far and getting updates soon...Pioneer has been putting out updates twice a year. I know that's the way it's been working for the other models. Usually you start at 1.0 which is what you should have now, and then you get 1.1 and eventually 1.2. Then the new software comes out for the new model (which you have to pay for). That's usually when the major map updates occur. The others are mostly to fix bugs with the firmware or to update features. Lastly, I am not aware of a way to train the Z1's voice recognition. If you are having problems with it not recognizing "AV operation" but it has no problem understanding a variant of the command, it is probably a bad unit. Others might tell you to place the MIC somewhere else (which can't hurt) but I think it's impractical since your unit understands other commands. If you have no problem getting used to saying a command other than the intended command, you should be alright but in my opinion, you should get it swapped. At the price these things are going for you shouldn't be having any problems and if you do you shouldn't have to deal with it. If you can get it swapped, tell them you only want the Z1 and microphone swapped so you won't have to rewire everything. Your dealer should have no problem with it.
