Anyone know which wire it is? what color should it be?
Also. When I installed the D3, my subwoofer wouldn't work. I have to check the connections again, but I'm sure they are fine.
What harness did you use to wire in the radio? As far as vss goes
Speed Sense blue/yellow 8K pin 9 @ instrument cluster
Notes: If vehicle has the midline audio system or BOSE, the VSS is also found at the radio, it is pink.
merry xmas.
I don't know what brand the harness is, but I've had it in the car for years now. I want the pink wire hooked up to the VSS. Is the wire behind the guage cluster?
you have to turn the sub out on in the menu
I also have a Nissan and connected the VSS wire to the pink wire from the stock Bose harness.... yet Speed Pulse in the connection status always reads 0. ![]()
Nissan what? How do you have it connected? The stupid taps?
2005 Nissan Altima w/ Bose .... Crutchfield told me it was the pink wire from the radio harness.... are they wrong?
pink wire is right. I have an 06 altima
Speed pulse will on read numbers while driving
