AVIC-N3 Two porblems and need help Please!!!!! New user
By studeng103 · Mar 07, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,390 views
Posted Mar 07, 2007 · 17:35 UTC#1
I have a 2003 tahoe with bose sound system. My friend and i installed the N3 and when we power it up neither disc will load. It says "insert approaite disk" then "reading disc" but then the message goes away and no action. It will play DVD's like it's supposed to but won't load GPS cd's. The unit is brand new out of the box with factory seal. I have also done the mod i found here and it also works great.
Second I have no sound, with my xm,radio,or ipod. Everything is registering on the screen and I can naviagte through. The only wire not hooked up right now is the vss wire. Does this matter? When I disconnect the aftermarket speaker wire harness fro the N3 and plug it into my factory it works fine? Anything that helps would be appreciated!!
HELP PLEASE!!!
Posted Mar 07, 2007 · 18:32 UTC#2
The sound issue, have you hooked up the guide on wire? If so that will constantly mute the headunit...to see if this is the case, try turning the volume up and see if Mute is displayed.
Posted Mar 07, 2007 · 20:44 UTC#3
Thank you for your response, this is driving me crazy and i really appreciate it!
The guide on wire is not connected, do you know where this connects? Also when I turn up the volume I get volume numbers not a mute message. ???
Posted Mar 07, 2007 · 22:03 UTC#4
With the n3, you shouldn't have to connect it. I am sorry I can't be of more help...only thing I can think of is, are you using the amp built into the radio or the rca to an external amp? If the built in one, do you have an external one to try? (Aka maybe you have a defective N3). It really sounds given all your problems that something is defective...you might want to call Pioneer tech support and get their take on it...
Posted Mar 07, 2007 · 23:03 UTC#5
I found the problem, I did think I needed the blue with white tracer wire (remote) connected. Apparently I did because of my factory amp. Thanks again
Oh, no idea about the gps?
Posted Mar 08, 2007 · 00:18 UTC#6
You could just have bad Dvd's (GPS Maps)...call Pioneer Tech Support
