cannot get custom background to appear
By Guest · Jun 01, 2006in Hacks/Mods💬 8 posts👁️ 2,500 views
Posted Jun 01, 2006 · 16:27 UTC#1
i have ver60 software and trying to change the bgopen.jpg on the disk, i opened with isoedit and swaped out the file, then selected burn, but the image is still the pioneer when i put it in the navi what am i doing wrong?
Posted Jun 01, 2006 · 19:29 UTC#2
Press the Reset button. Below the jog wheel.
Posted Jun 01, 2006 · 23:50 UTC#3
i just checked my disk and it looks like the file didnt change, still has the default image :( im not sure what im doing wrong, im using ultraiso i drop in the new files over BGOPEN, i get a dialogue that says replace existing file, i say yes, i save the file and select burn, dvd burns. What am i doing wrong?
Posted Jun 01, 2006 · 23:55 UTC#4
If you have a D1/D2 you need BGOPEN2 not BGOPEN
Posted Jun 02, 2006 · 02:03 UTC#5
i did bgopen and bgopen2 to be safe
Posted Jun 02, 2006 · 02:29 UTC#6
Hmm, well it must not be saving the iso.
Posted Jul 20, 2006 · 01:35 UTC#7
What a rip!
Does this mean that when I install this to my D1 that I won't get "city, skyline", etc for the animations?
What happens if I drag those into the directory for the D1? Anyone know?
Also, bgopen looks better than bgopen2. Anything wrong with simply copying bgopen over bgopen2? ;)
Posted Jul 22, 2006 · 01:01 UTC#8
Try using UltraISO instead. Create an image of the disc you want to modify then load it into UltraISO. Delete the file you want to modify first, then use the "Add Files" option under Actions and browse for the file you created. Load that into UltraISO, then use the "Make CD/DVD Image" option under Tools. Burn the image you created and you should be set. That's how I did it and it works beautifully.
