Hey! I needed some help with knowing what supplies I will need to install this unit. I have never done this before but im pretty good with electronics so I am sure I can figure it out. but to make it short and sweet I already went to crutchfield.com and they said the unit will fit so im guessing i wont need to alter my dash. What wires and or extra supplies or tools itself will i need? I am go to do the bypass as wll. Please let me kow im a newbie and need HELP. Thanks
Avic-D3 in my 2002 Honda Accord EX help!!!!
Dash Kit 99-7801
Harness 70-1721
Radio Removal. Pry out the clock between the 2 vents. Unplug and remove. Remove one philips screw from behind the clock. Remove 2 screws from the underside of the radio bezel. Grab radio bezel and pull forward. Disconnect harnesses and remove. Remove 4 philips screws to take out the radio.
Reverse Light green/black + driver side fuse box
Speed Sense blue/white ECM
Notes: Located at the first plug on the ECM, it is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet on the passenger side of the center console. There are 4 plugs total.
merry xmas
Thanks so much for the info. It is great but the last paragraph about the ECM and the reverse light and such, i have no idea what that is all about. From what you can see that i know( which is nothing) would you suggest i get someone to install it? thanks again for your help.
At that point I would say yes have it done. The last 2 are the colors/locations of those 2 wires.
