In Glass antenna
By Sabre3487 · Mar 08, 2007in Problems/Troubleshooting💬 8 posts👁️ 1,892 views
Posted Mar 08, 2007 · 18:09 UTC#1
I have 06 Zephyr, I have noticed some static every so often on some channels.
I forgot what your supposed to do, to "boost" your signal? Hook up the power antenna line?
Anyone have wiring pinout of Ford 06 24 pin?
Thanks,
Burn
Posted Mar 08, 2007 · 18:54 UTC#2
See attached.
Pin 5 is the power attena[/img]
Posted Mar 08, 2007 · 18:58 UTC#3
THanks, you don't happen to have all the pin - color codes?
Posted Mar 08, 2007 · 19:14 UTC#4
From my 2006 Ford Freestar Electrical Shop Manual:
1 = Voltage supplied at all times
2 = Switched power
3 = Illumination
4 = Ground
5 = Power antenna
6 = Not used
7 = Not used
8 = Spk LF+
9 = Spk LR+
10 = Spk RR+
11 = Spk RF+
12 = Spk RF-
13 = Ground
14 = Vehical Speed Signal
15 = Voltage Supplied at Start
16 = Not used
17 = Not used
18 = Steering Wheel Contols
19 = Not used
20 = Not used
21 = Spk LF-
22 = Spk LR-
23 = Spk RR-
24 = Not used
*Note: Pin 18 is which you connect the PAC-Audio Unit SWI-PS http://pac-audio.com/products/productsC ... 0Interface
Posted Mar 10, 2007 · 22:22 UTC#5
How do I know if the wire in slot 5 is the power Antenna wire?
What should the voltage read with a meter?
Reason is the pin locations you gave, I don't have any wires in 3&4, I do have a wire in 5 though.
So If put a meter on it what should it read +12v or ??
Thanks,
Burn
Posted Mar 10, 2007 · 22:37 UTC#6
Thanks,
Burn
If you are using a Ford brand 2004 or newer car/truck/van/SUV then pin 5 should be around 12V when the radio is ON.
The RADIO is feeding pin 5 the 12V
Posted Mar 14, 2007 · 23:28 UTC#7
Here is the pin assignents for the 06 Zephyr.
1 (BU-RD) 16 Voltage supplied at all times (overload protected)
2 (GN) 20 Accessory delay relay switched output
3 * * not used
4 * * not used
5 (VT-BK) 18 Antenna power
6 not used
7 not used
8 (WH) 20 Left front speaker +
9 (BN-GN) 20 Left rear speaker +
10 (BN-WH) 20 Right rear speaker +
11 (WH-VT) 20 Right front speaker +
12 WH-OG) 20 Right front speaker -
13 (BK-BU) 14 Ground
14 * * not used
15 (GY-BN) 20 Voltage supplied in Start (overload protected)
16 * * not used
17 * * not used
18 (GY-YE) 22 Audio steering wheel switch signal
19 (BU-WH) 22 Audio steering wheel switch return
20 * * not used
21 (WH-BN) 20 Left front speaker -
22 (BN-YE) 20 Left rear speaker -
23 (BN-BU) 20 Right rear speaker -
24 * * not used
In case you still need it.
Ken.
Posted Mar 15, 2007 · 00:20 UTC#8
its a purple black wire
