sirius radio not working
By tricky85 · Mar 08, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,340 views
Posted Mar 08, 2007 · 19:07 UTC#1
hey
i just installed SIRPNR2C in to my avic Z1. under the INFORMATION menu it says its not connected.. no signal... nothing
i got no sound...
but what i do have is the sirius menu.. i can see all the channels.. everythign.... it all looks good to go. and i did activate it as well..
on the top right it sais songs with a corss over it ( mean anything)
also it sometimes says NO COMPOSER
i got the yello wire from the sat unit wired to ACC not constant,,, it shouldnt be a problem should it?
iv never seen this problem and iam a autherized dealer here in vancouver!
any ideas??
thanks
Posted Mar 08, 2007 · 21:26 UTC#2
Check and make sure your IP cable is not backwards.
Posted Mar 08, 2007 · 21:32 UTC#3
Yellow must go to constant. Ipbus must be plugged into the black port on the sirius tuner. once's that's done reset the avic should take care of your problems.
Posted Mar 08, 2007 · 21:46 UTC#4
ye its pluged in to the input on the sirius unit it self...
that iam sure of!
iam gonna try to wire it up to constant! see what happens...
the bus cable it self isnt directional is it?
thanks guys
i'll give it a try
by the way.. by reset you mean press the little tiny button on the face plate right?
and is that going to delete all my setings and songs i have saved on the HDD?
Posted Mar 08, 2007 · 21:55 UTC#5
Yes the little button on the face. no it will not erase that stuff. No the ipbus cable is not directional. The ends have different colors but that doesn't really make much of a difference.
