Burning to a single-layer DVD
By Mosh1 · Mar 09, 2007in Custom Backgrounds💬 15 posts👁️ 3,889 views
Posted Mar 09, 2007 · 10:41 UTC#1
Can someone give me a walk-through on burning a background disc onto a single-layer DVD? I used the steps in the sticky, but still no help. Anyone have any ideas? Thanks guys.
Posted Mar 19, 2007 · 19:12 UTC#2
The sticky can't be written any clearer...
1. Extract you current NAV disc in .ISO format
2. Browse the .ISO and delete all "POI" files under /IDX/
3. Replace/add the backgrounds you need
4. Save .ISO
5. Burn
Posted Mar 26, 2007 · 17:46 UTC#3
anyboby knows if there's a free iso editor software that i can download? thanks
Posted Mar 31, 2007 · 07:50 UTC#4
I searched online found MagicISO Maker I beleve it's on download.com if you look there... Most won't allow you to save over 300MB. Unless you buy... Found a serial online It worked for me.... hope I could help you out...
Just enter this in after you install it...
Name:
Alllison M Dekel
Code: BTphuy2pnbwGxQE6mLkEOamhuWMFR3aFTSyF4SsLfO67FScJZglzXsWwOcYN3JaSQCc&1JitnAXjnlhEnQySqXogDau7vWccdVJI_LtWnAqMvmA6AOee4Qd7_ZqnI6&RTI__O4KMx_QW_OrR0OzbBphMqZqvwkseMtAKlsCdlI4
Posted Apr 01, 2007 · 19:16 UTC#5
How do you make the image file fit on a regular DVD? After I removed the poi files, added mine and saved it the size of the iso was 4.8 gigs and would not fit on a regular dvd. Are there any other files I can remove to reduce the size??
Posted Apr 02, 2007 · 05:54 UTC#6
Just my .02 but:
a) shouldn't you be burning to a CD and not a DVD? I know it works on a CD, but I'm not sure if it works on a DVD. Of course, I have a Z1 so maybe that's the part I'm missing.
B)zride: You must be pretty computer savvy and able to figure this out as your sig looks suspiciously like SQL script. :)
Posted Apr 02, 2007 · 22:37 UTC#7
Yeah, you're right, I will figure it out. Just thought you guys had an answer. They say never reinvent the wheel :wink:
Anyway, for cd's it has to be at least 1.8 megs of data in order to read. It also reads dvds according to the manual -- must be 170 megs i think.
Posted Apr 03, 2007 · 21:59 UTC#8
By the way, this is for the D3. Does this process even work for the D3??
Here is what it says in the manual
When you burn a CD-R/-RW and DVD-R/-
RW, make sure the total data size of the
CD-R/-RW and DVD-R/-RW is greater than
the amount noted below by storing
dummy data or other filler information.
Otherwise, the disc may not be recognized
by the built-in DVD drive.
— CD-R/-RW: 1.8 MB
— DVD-R/-RW: 170 MB
Posted Apr 03, 2007 · 23:57 UTC#9
You can only burn jpeg CD's for the Z's and N's.
With the D's, you have to delete the POI files, and add your custom pim files to the pim2din folder.
Posted Apr 04, 2007 · 03:55 UTC#10
R U Sure? That's not what the manual states. The manual for the D series (D3) says that you can burn jpeg images to a CD or DVD and it should read it.
Posted Apr 04, 2007 · 04:25 UTC#11
Figured it out. You CAN record to a CD with JPEG images. you just have to be SURE that there is a /PICTURES folder with <20 jpeg files and that the full size of the disk is >1.8 MEGS thats it. Simple. Done.
Posted Apr 04, 2007 · 05:38 UTC#12
Told ya, you could do it! :wink:
Posted Apr 14, 2007 · 20:27 UTC#13
Name:
Alllison M Dekel
where did you git it or what did you do to getthis code to work
Posted Apr 14, 2007 · 23:56 UTC#14
I just copied all the files except the poi
Folder and re burned it to t DVD and worked but now I can't search. Nothing not even map nothing
Posted Apr 15, 2007 · 00:26 UTC#15
Ummm how would you be able to search for anything if you deleted all the POI files? Geez.
Just pay the $5 and get a dual layer dvd-r to burn an exact copy!
