Best way to connect a Sandisk Sansa e200 series MP3 player?
By Risko · Mar 10, 2007in General💬 11 posts👁️ 2,136 views
Posted Mar 10, 2007 · 22:15 UTC#1
I am trying to avoid buying an IPOD just for clean integration and want to be able to connect my Sansa e270 to my D3. I know Pioneer makes a USB connectivity kit, but how will the content from the Sansa be displayed on the D3? I found a Pioneer aux. connector at Target that uses a set of RCA cables and a BUS connector and then hooks into the headphone jack of an MP3 player, but I'm just not sure how easy it would be to navigate through the content on the Sansa if I used this...or if it even compatible w/ the D3. Any thoughts would be appreciated.
Posted Mar 10, 2007 · 23:09 UTC#2
http://imedock.com/zune.htm go here an see the sandisk ime dock but its not out in store it said feb for the date. but dont no
Posted Mar 10, 2007 · 23:11 UTC#3
the usb kit is your best bet, it should display like an mp3 cd
Posted Mar 11, 2007 · 04:48 UTC#4
Which usb kit are you referring to?
Posted Mar 11, 2007 · 13:48 UTC#5
the pioneer one
Posted Mar 11, 2007 · 17:59 UTC#7
From what I've read about the Pioneer USB kit, it will work as an external device... which is another way to say it will work like crap. You'll get one line of text, and limited use.
Your best bet is to buy an iPod and get complete and easy control. But if you really don't want to, you can take any headphone to headphone jack and put it in the headphone jack in the MP3 player to the input on the front of the D3.
Posted Mar 13, 2007 · 01:47 UTC#8
I had the same question regarding hooking up a Palm Treo to an Avic-z1. The Treo can play internet radio that I want to hook up to the z1. It has a 3.5 headphone jack. It looks like you can use a cable to go from the earphone jack to RCA cable which can hook into the Z1. Will this work or should I go with USB connection?
Posted Mar 13, 2007 · 03:03 UTC#9
should work,you just wont gat any display,just the audio. hows your treo work with the bluetooth adapter, those phones dont work well with a lot of stuff
Posted Mar 13, 2007 · 15:28 UTC#10
which would work better the rca cables or usb? I don't have a treo yet but I wanted to know before I get one.
Posted Mar 13, 2007 · 20:05 UTC#11
not sure, usb is new and havent installed it yet to say anything good or bad
