Nav Night-time display?
By Sabre3487 · Mar 12, 2007in General💬 20 posts👁️ 3,967 views
Posted Mar 12, 2007 · 15:18 UTC#1
My stock wiring harness does not have illumination wires. I assume they are on the CAN BUS.
So without those is there a way to get the map into Night mode? I switch it in the settings and it does not do anything.
Anyone know? Maybe grounding the illum wire (lights always on type of thing)
Thanks,
Burn
Posted Mar 12, 2007 · 18:02 UTC#2
You could tap it from the parking lights wire. Thus when you turn on your lights, It will switch to nighttime mode. What car do you have?
CiD
Posted Mar 12, 2007 · 18:07 UTC#3
I have 06 Linc Zephyr.
I don't understand why you can't just switch the thing into night mode regardless of the lights.
Do you know what it is that the illumination wire does when on?\
ie. 12volts = on or 0v etc??
Posted Mar 12, 2007 · 19:31 UTC#4
settings > map display options > day/night display
to manually change it and works for me
Posted Mar 12, 2007 · 19:38 UTC#5
Yeah, however I do not have the illumination wire hooked!
Called pioneer and they said it needs that wire, which is stupid that you can't change it on your own.
So any one know what else to use or tap into?
Posted Mar 12, 2007 · 22:43 UTC#6
Parking Lights+ gray/yellow + driver kick or SJB, conn. E, pin 30
Notes: The SJB (Smart Junction Box) is part of the fuse/relay box under the driver side dash.
Posted Mar 13, 2007 · 00:18 UTC#7
That only applies when the illumination is already hooked up. Without it it does nothing,
Posted Mar 13, 2007 · 02:37 UTC#8
hey cntry, that sounded just like directechs to me
Posted Mar 13, 2007 · 02:50 UTC#9
That's exatly what it was. Too lazy to type it out so I copy and paste.
Posted Mar 13, 2007 · 12:41 UTC#10
I need to connect the orange white wire that came with the crutchfield harness with the parking light??? I forget if there was a orange/white wire on the back of my pioneer harness..........
Posted Mar 13, 2007 · 13:11 UTC#11
HELP ME - QUESTION DIRECTLY ABOVE
Posted Mar 13, 2007 · 13:33 UTC#12
What are you talking about? You don't connect the crutchfield harness to the parking lights. If there is no orange/white wire in your pioneer harness, then this thread is totally useless to you because whatever radio you have doesn't have a dimmer.
Posted Mar 13, 2007 · 13:39 UTC#13
Ok, I know thier was a orange wire, but i was not sure if the pioneer D3 harness had an orange / White wire.... i just dont rember..I installed it a few days ago.....Does the harness have a orange/white wire? and if it does ...do i connect it to the parking lights????
Posted Mar 13, 2007 · 13:44 UTC#14
yes and yes
Posted Mar 13, 2007 · 13:59 UTC#15
thank you
Posted Mar 13, 2007 · 14:38 UTC#16
yes all it does is give 12volts on, and 0volts off. If you want control over it, you can attach it to ignition and just install a switch.
Posted Mar 24, 2007 · 06:39 UTC#17
I have a similar issue... on my forester (05) there is a negative and a positive side to the illumination wires. Avic has only one illum. wire... what to do?
Posted Mar 24, 2007 · 06:41 UTC#18
Oh... I forget anyone know where to find the vss wire on my car? and what color it is perhaps?
Posted Mar 24, 2007 · 12:28 UTC#19
Speed Sense green/yellow ECM, 20 pin plug, pin 10 The ECM (Engine Control Module) is below the glove box. The VSS wire is also found behind the instrument cluster in the middle plug.
Posted Mar 24, 2007 · 17:28 UTC#20
yup yup
