AVOX JUKEBOX HELP
By jaytrey · Mar 13, 2007in Hacks/Mods💬 5 posts👁️ 1,502 views
Posted Mar 13, 2007 · 02:17 UTC#1
hey guys,
i just installed the laptop hd into my avox today and i put in the cd trying to get everything set up. however, when i loaded the cd that said i needed the 98 driver. the install wizard would not complete saying that i am not using win98. i know that a lot of people have bought this thing and i'm pretty sure they are not using win98 either. does anyone know what to do now? i'm completely stuck. i can't even get past step 1.
so after everything is loaded, then i go dl the new firmware correct? 1.4.7?
is that the latest out?
please help me out. i'm pretty stressed as this is brand new, just opened it today...btw my d3 just came in the mail today too...but i been so stressed with this thing that i haven't even had time to look at it.
Posted Mar 13, 2007 · 02:19 UTC#2
Damn it Paisan where are you now? Seems our resident AVox rep has disappeared.
Posted Mar 13, 2007 · 02:20 UTC#3
i know....i been trying to pm him too because i knew he could help me personally, but he has not been replying.
it doesn't make sense that they would MAKE you use win98 to use this thing. that is so friggin old
Posted Mar 14, 2007 · 01:36 UTC#4
still hoping someone can help me out here with the avox
but i did get it to work.
what i was wondering. are a few things. i tried putting music onto the thing and it worked. however. is there a repeat button? once the songs in the folder end, it just stops. is there a repeat button to keep the music playing?
when i open up my pics folder, i still see my music folders. is that supposed to happen? just wondering. it does not categorize them into the tabs on the avox?
for the background pics. it said that rename it to "mybg.jpg" i could not get that to work.
where did all the avox users go?
Posted Apr 08, 2007 · 02:12 UTC#5
Are you guys running this off of windows xp? If so, all you have to do is right click on the .exe (of the program your trying to run) select properties, then you should see a "compatibility" tab. Click this> place a check in "run this program in compatibility mode for:" select windows 98, apply then ok. Now try to re-run the executible. Usually this works, but not always.
