D3 and factory installed XM / CD Changer
By deversole · Mar 13, 2007in General💬 10 posts👁️ 1,663 views
Posted Mar 13, 2007 · 10:31 UTC#1
Hey guys. I am considering buying the D3 for my 2004 Yukon Denali. I already have XM in my vehicle. Can I use my XM adapter with the D3, or do I need to purchase another? Also, I have a factory installed CD changer. Will that work with the D3 as well? Thanks!
Posted Mar 13, 2007 · 11:39 UTC#2
nope, you'll be replacing both of them
Posted Mar 13, 2007 · 13:23 UTC#3
You can however reuse the factory xm antenna.
Posted Mar 13, 2007 · 15:31 UTC#4
Thanks for the replies guys. I wonder if there is some kind of adapter that would allow me to use the CD changer. What would be the benefit of reusing the factory XM antenna other than not having to install another? Hrmm...it seems I have a lot to think about before I get the D3...
Thanks again!!
Posted Mar 13, 2007 · 16:33 UTC#5
Can't use the changer either. Its not made by Pioneer. The advantages of using the factory XM antenna is that is would retain the factory look, you wouldn't have to run the wire for the Pioneer one, and you wouldn't have another antenna on your dash or roof
Posted Mar 13, 2007 · 19:14 UTC#6
Ahh ok, that sounds good. Thanks for the replies!
Posted Mar 13, 2007 · 23:04 UTC#7
Is any kind of adapter needed when using the factory antenna? I'm thinking of doing this myself on an Audi A3.
Posted Mar 13, 2007 · 23:19 UTC#8
Dunno for vw's. GM's and fords you can remove the plastic casing.
Posted Mar 20, 2007 · 19:26 UTC#9
I have a VW Jetta 2006 that had an OEM nav system in it. The GPS antenna is the right cable but even after you take off its plastic housing, the shape of it won't allow you to put it in because it's 'L' shaped. The XM antenna is the same type of cable as the factory GPS antenna cable; however, the avic d3 requires you to get an adapter for the XM antenna if you want to use it.
Posted Mar 22, 2007 · 22:33 UTC#10
So if I understand correct, you can use the OEM antenna but need a convertor.
Do you have a part number for the convertor. I have a passat, and want to use the OEM antenna for SAT.
