pioneer D3 oem trim
By Ricochet · Mar 13, 2007in General💬 14 posts👁️ 2,726 views
Posted Mar 13, 2007 · 13:19 UTC#1
how did you guys put on your Pioneer trim? i don't see any clips or 2 way tape or anything.
thanks
Posted Mar 13, 2007 · 14:21 UTC#2
yeah and the trim ring doesnt seem to fit onto the D3 really. Its inner rim is bigger than the forward face of the D3. whats up with that?????????????
Posted Mar 13, 2007 · 14:25 UTC#3
well on my car i have to use it, so i might have to trim it down a bit or something
but i'm just woundering how the ppl that used it got it on theirs?
Posted Mar 13, 2007 · 14:26 UTC#4
I have to use it on my car also. Without it theres a gap and you can see metal and stuff. I'm in the same perdicament. Anyone out there can help us out?
Posted Mar 14, 2007 · 19:52 UTC#5
bump
Posted Mar 14, 2007 · 20:22 UTC#6
I had to be creative and use 2 side foam tape.. I also filed down the trim to make it fit right...
This is what i came up with:
CiD
Posted Mar 14, 2007 · 21:02 UTC#7
Is the purpose of the foam tape to keep the trim ring stuck where it is?
Also what did you use to file it down?
Also does anyone know where we can get spare trim rings? becasue i'm pretty sure i might screw it up the first time.
Posted Mar 14, 2007 · 21:16 UTC#8
i used it as a extra measure to hold it in place and to prop the trim up so it would match where the corners of the dash plate should meet with the original oem radio.
I used a tradional flat file and a vise... i vised the file (used a cloth in between so i don't damage the file and then filed the sides of the trim until it fit.. i usually took 2mm off then checked to see if it fit.
I would suggest usuing the avic cardboard box and make a dummy replica of the opening of your dash then use that as a guide to trace how much you need to trim off until the trim ring fits.
CiD
Posted Mar 14, 2007 · 21:31 UTC#9
I see, thanks alot man.
I wonder if we can get replacement trim rings anywhere???
Posted Mar 22, 2007 · 21:24 UTC#10
Anyone know if a D2 trim ring will work on a D3 ? I used a cage for a D2 to install the D3 in my Jetta. From the picture on Pioneer's website it appears to have a type of clip to keep it in place.
http://parts.pioneerelectronics.com/par ... um=CNS8298
Posted Mar 22, 2007 · 21:25 UTC#11
Posted Mar 22, 2007 · 23:54 UTC#12
are you stuttering?
you should be able to use the d2 trim ring, the one that comes with the d3 is really meant to go between the radio and the dash bezel, not on the outside
Posted Mar 23, 2007 · 00:22 UTC#13
I used the existing trim that I dremeled and sanded down for my D1. Works just fine on the D3.
Posted Mar 23, 2007 · 23:26 UTC#14
The D2 trim panel is about as useful as the the one that comes with the D3. It does have clips, but the D3 doesn't have anything for them to attach to. Back to the drawing board. I did file down the D3 trim, but to me it doesn't look professional.
