Anyone know if the D3 uses the same wiring harness that plugs into the back as the D1? If so, how different is it? I want to change my D1 to the D3 but I don't want to re-splice all the wiring again (my car has no wiring harness that's compatible with aftermarket stereos, unfortunately).
Avic-D1 vs. D3 wiring harness...
I would assume that its the same. I'll be getting my D3 and replacing my D1 this weekend. I'll update once I finish the swap.
It's different. Match the colors, those are the same.
Thanks, if the colors are the same, then it shouldn't be too bad.
Yes the colors on 98% of aftermarket radios made in the last 8 years is the same.
Yellow - constant
red - switched +12v
black - ground
blue - power antenna
blue/white - amp turn on
black/white - amp ground
orange - illumination
orange/white - dimmer
orange/black - negative dimmer
brown or yellow/black - cell mute
white - left front +
white/black - left front -
gray - right front +
gray/black - right front -
green - left rear +
green/black - left rear -
purple - right rear +
purple/black - right rear -
Incidentally that is probably the only universal thing in the car audio world. On a side note to any wanna be installers in the group. That list would be a good thing to remember.
