CD wont play
By alumniu · Mar 13, 2007in Problems/Troubleshooting💬 9 posts👁️ 1,355 views
Posted Mar 13, 2007 · 20:05 UTC#1
I just purchased an AVIC D1 for my BMW 330i. Wired it up and found out that it wont play a cd! This seems like the most simple function of this unit (other than fm) and doesnt seem like there could be much room for error. Can anyone help! - oh, and I got it off ebay
Posted Mar 13, 2007 · 20:34 UTC#2
What kind of CD is it?
Try a regular, non-copied CD. If that works, then check how you are burning your cds. I'm pretty sure the CD has to be 'closed' to work in the AVICs.
If a regular CD doesn't work, then you unit is defective.
Posted Mar 13, 2007 · 21:03 UTC#3
yeah, its not a ripped cd. Its a store bought cd, and ive tried several different ones too. Only other think i can think of doing is to cut all the connections i have made to the wiring harness and rewire them (maybe two wires arent all the way connected). I appreciate any help.
Posted Mar 13, 2007 · 21:24 UTC#4
Is the CD playing, but you're just not hearing any sound?
Or is it failing to load the CD?
If you're not hearing any sound, then its possible that your wiring is wrong. But if it won't load the CD, then that has nothing to do with your wiring.
Posted Mar 13, 2007 · 21:40 UTC#5
sounds like a possibility. It does load and the tracks pop up but only with a line, no track names. And the song count is going at the top right hand side off the screen like its playing but no sound. I guess ill try undoing the wiring to the harness and rewire it up. I hope thats the only problem!
Posted Mar 13, 2007 · 21:45 UTC#6
you have a factory amp in the car. The amp is not turning on when you play a cd. In the initial menu you have to change the auto antenna setting from radio to source. That'll fix your problem.
Posted Mar 13, 2007 · 22:03 UTC#7
The CD has to have CD text written on it along with the track names for it to display the text.
Most CDs nowadays are produced with CD text, but its possible that the one you are using wasn't.
You can always copy the CD to your computer, and burn it with CD text. You'll have to use a program like Nero.
Posted Mar 13, 2007 · 22:44 UTC#8
Thnks for the help guys. It was my own duma$$ fault in the wiring. I hooked up the blue wire from the harness labeled "power antenna" to the wire on the D1 labeled "auto antenna remote control". WRONG. Once i disconected this wire and hooked it up to the other blue wire coming from the D1 (which was spliced by the previous owner and isnt labeled), all systems go. Cant say thanks enuff for everyone who posts on these forums.
Posted Mar 13, 2007 · 22:53 UTC#9
Great glad it works. Enjoy!
